stroker lsj build
Old 05-13-2013, 07:05 AM
  #651
Tjolley's Avatar
This is just the 2.0 still
I backed off the throttle slightly and shook the wheel mid 3rd gear to regain traction
Old 05-13-2013, 08:58 AM
  #652
mrbelvedere's Avatar
this is why i would love to play with a stock m62 lsj with a 4.45 trans. with a 23" tire you've got ~4.84 gear. full bolt ons that thing would be deadly
watch yourself youll be selling the snal
Old 05-13-2013, 01:35 PM
  #653
EXsoccer1921's Avatar
hell no. that's never going to happen
Old 05-13-2013, 01:44 PM
  #654
225/45/13 ~4.75 on a stock trans. 5.15 on a 4.45 lol.
Old 05-13-2013, 02:15 PM
  #655
armcclure's Avatar
I have 245/35 which is like 23.8 iirc. Yeah it rips. Too much I'm just gonna pulley up till 2nd can grip then cut the spray loose in 3rd
Old 05-13-2013, 04:54 PM
  #656
what size wheel though.
Old 05-13-2013, 05:11 PM
  #657
Powell Race Parts's Avatar
ex soccer gets it. Arm, you still need to catch up.
diameter= gearing
wheel size=side wall height
hey Ex, wheres that outstanding internet picture of the two rails leaving the line with showing sidewall/tire distortion a snap shot in real time, to illustrate what you got going on here?
Old 05-13-2013, 07:58 PM
  #658
armcclure's Avatar
17" wheels. I "get" it but I'm not willing to buy 15" rims and slicks for the handful of passes ill make this year. My racing of any type rarely happens from a dig outside of the strip.
I fully realize that I don't have a great drag setup, just want to do the best I can with what I've got.
Old 05-14-2013, 08:45 AM
  #659
Tjolley's Avatar
Ok well got my parts list together for my cavalier.
It spun a rod bearing a week ago and has a nasty knock.
So in gona pull the engine and rebuild it real quick.
New Crank
New rods
New rod bearings
New main bearings
New head bolts
New main bolts
New rod bolts
All new seals
New rings
Grand total $575.35 shipped.
Old 05-14-2013, 11:55 AM
  #660
armcclure's Avatar
That's some bullshit lol why can't our stuff be that cheap
Old 05-14-2013, 12:07 PM
  #661
Tjolley's Avatar
Idk.
A total engine seal kit with head bolts is like 89$
Old 05-15-2013, 06:45 PM
  #662
Tjolley's Avatar
Ok well ill have my rotating assembly back early next week for the 2.4 lsj.
Had a few issues with the parts i bought from eagle. They got it all straighten out. Need to hone the block then i can assemble the bottom end.
Need to finish porting the head and get the combustion chambers ceramic coated then powder coat it then get it decked.
Now onto the cavalier
All the parts shipped out today.
So hoping to have the engine out and disassembled all cleaned up wen they show up.
Old 05-18-2013, 09:16 PM
  #663
Tjolley's Avatar
Just ordered the ARP timing bolts. Just need to mod the stock ones now.
Old 05-21-2013, 04:01 PM
  #664
Tjolley's Avatar
Clean rockers
Old 05-21-2013, 05:42 PM
  #665
TStone's Avatar
yay clean rockers
Old 05-21-2013, 05:47 PM
  #666
Tjolley's Avatar
Oh ya lnf rockers
Old 05-21-2013, 05:57 PM
  #667
TStone's Avatar
What did you do about the retainers?
Old 05-21-2013, 06:16 PM
  #668
Tjolley's Avatar
Supertech titanium made by bates
Old 05-21-2013, 06:17 PM
  #669
TStone's Avatar
I meant did you do anything to them since you're gonnna run LNF rockers?
Old 05-21-2013, 06:23 PM
  #670
Tjolley's Avatar
Oh
No they should pop right in. The spring, valve and all that r interchange able.
Old 05-21-2013, 06:57 PM
  #671
TStone's Avatar
lol
Old 05-21-2013, 09:34 PM
  #672
Tjolley's Avatar
Look wat showed up today.
Old 05-21-2013, 09:56 PM
  #673
Tjolley's Avatar
Old 05-21-2013, 11:27 PM
  #674
Originally Posted by Tjolley
Oh ya lnf rockers
actually those aren't lnf rockers they are lsj exhaust rockers there was a rocker change between 04 and 07 and only the exh side on the lsj got that rocker after the change
left rocker lsj exh right lsj int
lnf uses both on left
when going with heavier valve springs use the hd rocker(lsj exh/lnf)
Old 05-21-2013, 11:53 PM
  #675
Tjolley's Avatar
I wonder if my 07 has these rockers cuz i dont remember seein any different ones wen I had the head apart. I might have the valve cover off this weekend ill definitely be checking that out.
Quick Reply: stroker lsj build
