stroker lsj build
Old 05-22-2013, 09:20 AM
  #676
mrbelvedere's Avatar
Originally Posted by Tjolley
I wonder if my 07 has these rockers cuz i dont remember seein any different ones wen I had the head apart. I might have the valve cover off this weekend ill definitely be checking that out.
my garage has never had an lnf head in it and I have several of those rocker the exh rocker takes more abuse then the intake
Old 05-24-2013, 06:00 PM
  #677
Tjolley's Avatar
Made some fittings to delete the water pipe across the back of the engine.
Old 05-24-2013, 11:19 PM
  #678
how are you going to hold the fittings in place
Old 05-24-2013, 11:20 PM
  #679
Powell Race Parts's Avatar
click.
Old 05-24-2013, 11:35 PM
  #680
Omnigear's Avatar
Clean rockers
no big scorching on em?
Old 05-24-2013, 11:53 PM
  #681
your pic dose not work
  #682
c130aviator's Avatar
those fittings are going to be a bit more restrictive than the stock crossover pipe.
Old 05-24-2013, 11:55 PM
  #683
Omnigear's Avatar
i know i took off the link in the quote, its his picture of the rockers.
Old 05-24-2013, 11:57 PM
  #684
not at all
Old 05-25-2013, 12:00 AM
  #685
by the time he threads whatever he is using for the delete into those fittings, the inner diameter is going to be even smaller.
Old 05-25-2013, 12:01 AM
  #686
dose not matter as those are not intended for a stock pump cooling system
Old 05-25-2013, 06:37 AM
  #687
Tjolley's Avatar
My electric water pump is a -12 (3/4) so i made adapters that had 1" pipe threads. I think that is plenty big enought.
Old 05-25-2013, 06:42 AM
  #688
Tjolley's Avatar
Oh well i have a few tricks up my sleeve..lol
Old 05-25-2013, 10:43 AM
  #689
two 90 degree elbows with a piece of stock welded between them to hold them in like the stock crossover does? Or each elbow that is treaded into those welded to a bracket then to an adjacent bolt?
Old 05-25-2013, 10:56 AM
  #690
Tjolley's Avatar
No
Im thinkin to just put a bolt or two in the side or just weld the thing in all together. Idk yet. Have a good size party to put together tonight so no cobalt work today.
Old 05-27-2013, 08:31 PM
  #691
Tjolley's Avatar
Had a blast saturday night. Ended up not pulling the engine on the cavi sunday cuz i had to rescue and put a new radiator in a members cobalt sunday. Was not fun doing this with a hang over. Lol
So i got the engine out of the cavi in about 3 hrs today.
I have the new crank already just need to recondition the rods and start assembling.
Old 06-13-2013, 06:54 AM
  #692
Tjolley's Avatar
All ready to get balanced. Dropping it all off today.
Old 06-13-2013, 08:58 AM
  #693
looking good tj
Old 06-13-2013, 09:40 AM
  #694
Tjolley's Avatar
Anybody want to guess at what I did to the crankshaft besides the keyway?? I'll give you a hint I deleted something.
Old 06-13-2013, 09:45 AM
  #695
adamwamadam's Avatar
That's easy :P no more second chain
Old 06-13-2013, 09:48 AM
  #696
Tjolley's Avatar
Yes sir. I made a spacer that is pressed on to the crank.
Old 06-13-2013, 09:51 AM
  #697
Tjolley's Avatar
Forgot to snap a picture of the weight difference.
About 12oz weight loss lol.
This bitch is gona be real edgy
Old 06-13-2013, 10:07 AM
  #698
Props man that crank is art!
Old 06-13-2013, 10:12 AM
  #699
How tight is it pressed? I would also imagine that would add stability to the key, possibly help prevent breaking the key way
Old 06-13-2013, 11:14 AM
  #700
Tjolley's Avatar
About 0.002
Quick Reply: stroker lsj build
