stroker lsj build
#854
Exhaust is more or less done.
Proly Wont be any more work done this week. Im getting ready to head to Steve's this weekend to build and install his engine.
#868
Ok so did some comparing between the GMRs and stock.
The stock base circle spec is 1.181 -0.003 so almost 30mm
GMRs is 1.102 right at 28mm.
With that 2mm difference in the base circle i need to gain 1mm of valve stem length and lifter hight.
I pulled a lifter a part to take some measurements. Looks like the lifters have about 0.045 more travel. Which is good cuz i only need 1mm or 0.039. Now for the valves.
Couple of options i can choose from.
1 buy custom valves 1mm longer
2 have the seats cut 1mm deeper
3 mod the followers.
Im Gona attempt the mod the followers to gain the needed 1mm.
I ordered the needed parts from summit cost me 36$.
#870
The thing about slaping solids in is it throughs the valve geometry off and side loads the stem causing the valve train to bind.
Interested in the welding a shim to the followers.
#871
He said weld to the lifter/adjuster. Which would throw the rocker geometry off by the same amount.
Which brings up the point: is 1mm even worth messing with? Do you really believe its going to throw things off THAT much? Trig it out with the length of the valve with the distance from the lifter to valve stem. You're talking about a tiny fraction of a degree here.
#872
The point of this is to correctly run the GMRs and maintain the stock valve geometry.
#875
Well Im sticking a 1mm lash cap on the valve and moding followers to fit over.
I pulled a lash adjuster apart and came up with 0.045 or extra travel Wich is good cuz i only need 0.039.
I have a few sets of solid lifters laying around now so i can easily use them if this idea Dosnt work
