stroker lsj build
Old 10-07-2013, 12:48 PM
  #851
Tjolley's Avatar
Oh trust me it is.
Old 10-08-2013, 04:05 PM
  #852
hungryhip-ccp's Avatar
What's going on in here?
Old 10-08-2013, 10:27 PM
  #853
RooTBeeR's Avatar
havent seen you around in years lol
you still have your hahn stage 5 turbalt?
Old 10-09-2013, 07:38 AM
  #854
Tjolley's Avatar
Exhaust is more or less done.
Proly Wont be any more work done this week. Im getting ready to head to Steve's this weekend to build and install his engine.
Old 10-09-2013, 09:38 AM
  #855
RooTBeeR's Avatar
He building #3?
Old 10-09-2013, 12:07 PM
  #856
Tjolley's Avatar
Second built engine. This will be #3 for the car.
Then my car is gettin #4
Old 10-09-2013, 01:02 PM
  #857
RooTBeeR's Avatar
So many engines!!!
Anyone using that giant exhaust port head?
Old 10-09-2013, 01:38 PM
  #858
Tjolley's Avatar
U taking about the head JR started to do?
Old 10-09-2013, 02:38 PM
  #859
RooTBeeR's Avatar
The one he welded up the egr ports on and then ported. Did that not get finished?
Old 10-09-2013, 02:43 PM
  #860
SSfamilywagon's Avatar
Nice progress. Keep it up. To bad I can't help this weekend.
Old 10-09-2013, 02:49 PM
  #861
RooTBeeR's Avatar
Tjolley
Whee abouts are you?
Old 10-09-2013, 04:34 PM
  #862
Tjolley's Avatar
Im in Modesto California. About 350 miles one way from Steve
Old 10-09-2013, 05:15 PM
  #863
RooTBeeR's Avatar
Yup know right where that is.
Damn just here for a weekend or what?
Old 10-09-2013, 05:29 PM
  #864
Tjolley's Avatar
Yes sir
Hoping to be there by midnight Friday night Saturday morning and head home Sunday around 3 or 4 pm
Old 11-12-2013, 02:07 PM
  #865
Tjolley's Avatar
Finished the head last night
GMR Cams showed up.
Bates solid lifters.
Old 11-12-2013, 02:13 PM
  #866
574
574's Avatar
So you gonna fire it up this weekend?
Old 11-12-2013, 02:20 PM
  #867
Tjolley's Avatar
If all goes well with the Gmr cams install
Old 11-14-2013, 07:43 AM
  #868
Tjolley's Avatar
Ok so did some comparing between the GMRs and stock.
The stock base circle spec is 1.181 -0.003 so almost 30mm
GMRs is 1.102 right at 28mm.
With that 2mm difference in the base circle i need to gain 1mm of valve stem length and lifter hight.
I pulled a lifter a part to take some measurements. Looks like the lifters have about 0.045 more travel. Which is good cuz i only need 1mm or 0.039. Now for the valves.
Couple of options i can choose from.
1 buy custom valves 1mm longer
2 have the seats cut 1mm deeper
3 mod the followers.
Im Gona attempt the mod the followers to gain the needed 1mm.
I ordered the needed parts from summit cost me 36$.
Old 11-14-2013, 07:55 AM
  #869
Josh@ottp's Avatar
If you don't want to run solids you can take a spacer that is the right diameter and thickness and tig weld them to the bottom of the stock lash adjusters to hold them in place.
Old 11-14-2013, 08:15 AM
  #870
Tjolley's Avatar
Hmm ok
The thing about slaping solids in is it throughs the valve geometry off and side loads the stem causing the valve train to bind.
Interested in the welding a shim to the followers.
Old 11-14-2013, 08:21 AM
  #871
armcclure's Avatar
He said weld to the lifter/adjuster. Which would throw the rocker geometry off by the same amount.
Which brings up the point: is 1mm even worth messing with? Do you really believe its going to throw things off THAT much? Trig it out with the length of the valve with the distance from the lifter to valve stem. You're talking about a tiny fraction of a degree here.
Old 11-14-2013, 08:25 AM
  #872
Tjolley's Avatar
Oh duh lol i saw weld and instantly thought followers.
The point of this is to correctly run the GMRs and maintain the stock valve geometry.
Old 11-14-2013, 09:43 AM
  #873
Powell Race Parts's Avatar
SMH; weld shim/adjuster.
Old 11-14-2013, 10:36 AM
  #874
Josh@ottp's Avatar
I think the number is 1.5 degrees. That's going off of memory though. I have ran cars like this with no problems. If you want to maintain stock geometry you would have to raise the valve and lash adjuster the same amount.
Old 11-14-2013, 10:49 AM
  #875
Tjolley's Avatar
Funny thing is i just came up with 1.24 degrees..lol
Well Im sticking a 1mm lash cap on the valve and moding followers to fit over.
I pulled a lash adjuster apart and came up with 0.045 or extra travel Wich is good cuz i only need 0.039.
I have a few sets of solid lifters laying around now so i can easily use them if this idea Dosnt work
Quick Reply: stroker lsj build
