stroker lsj build
#953
Isn't the LE5 crank cast how much hp is it good for?
#960
Car sounds amazing with the Cams and high compression.
It revs like a ****.
Havnt messed with the tune this was the tune from my 2.0 un Modied.
After i warmed up i drove it a Lil and the car seemed to always want to die coming back to idle. Im sure its just the tune.
#962
I believe so. Wasn't really paying attention. I was waatching everything eles.
I knoticed im only making 3-5 of vacume im sure my tune was all over the place. Cuz my wideband was
#965
valve cover 50
head traded value 250
supertech valves .5mm os 450
supertech springs and seals 450
folowers 75
lifters 150
GMR cams traded value 350
custom head gasket 210
ZZP GEN II girdled block 1750
gasket kit 75
custom wiseco pistons 575
total seal rings 210
trend performance wrist pins 125
eagle l61 rods 450
le5 crank 320
oil pan 50
block machine work 200
flywheel 350
clutch 650
1/2 arp head studs 250
ATI 400
arp flywheel bolts 100
gm main bearings 75 i think
clevite rod bearings 80
water pump 50
thermostat housing 50
this is majority of the list theres still alot of lil things to add
folowers 75
lifters 150
gasket kit 75
eagle l61 rods 450
le5 crank 320
oil pan 50
flywheel 350
clutch 650
ATI 400
water pump 50
#970
I wanna get a 2.4 stroker for my lnf
#975
so now that i have a few miles on this 2.4. most everything seems good to go.
my oil cooler arives today so the car is going back in the garage to pull the front bumper off to mount this huge cooler and oil thermostat housing and lines to go with it all. new oil pressure guage and oil temp guage on the way
