stroker lsj build
Old 11-30-2013, 08:19 PM
  #951
armcclure's Avatar
I almost grabbed one of those. I think mine will be just fine now that the ac and he are out of the way though
Old 11-30-2013, 08:34 PM
  #952
Tjolley's Avatar
Ya more then lickly.
So i get the car all buttoned up ready to fire up.
And the canister has a crack now. Im Gona try to make it work we will see.
Old 12-01-2013, 01:59 AM
  #953
KMO43's Avatar
Isn't the LE5 crank cast how much hp is it good for?
Old 12-01-2013, 05:42 PM
  #954
ItalianJoe1's Avatar
All the ecotec cranks are pretty beefy. I'd be surprised to see anyone having trouble at anything less than 600hp.
Has anybody broken a 2.4 crank?
Old 12-01-2013, 11:33 PM
  #955
Tjolley's Avatar
It lives!!!
Old 12-01-2013, 11:36 PM
  #956
Tjolley's Avatar
This is the very first start up notice the new engine rattles and noises. After about 2 min its silent. Runs well
The valve train sound like stock.
Old 12-02-2013, 01:11 AM
  #957
South Central *********
JapEatr's Avatar
Congrats!
Old 12-02-2013, 01:13 AM
  #958
slitterell's Avatar
Congratulations!
Old 12-02-2013, 03:12 AM
  #959
SSfamilywagon's Avatar
Nice clean first start.
Old 12-02-2013, 03:22 AM
  #960
Tjolley's Avatar
Car sounds amazing with the Cams and high compression.
It revs like a ****.
Havnt messed with the tune this was the tune from my 2.0 un Modied.
After i warmed up i drove it a Lil and the car seemed to always want to die coming back to idle. Im sure its just the tune.
Old 12-02-2013, 06:49 AM
  #961
armcclure's Avatar
Was your speedo working
Old 12-02-2013, 08:55 AM
  #962
Tjolley's Avatar
I believe so. Wasn't really paying attention. I was waatching everything eles.
I knoticed im only making 3-5 of vacume im sure my tune was all over the place. Cuz my wideband was
Old 12-02-2013, 09:43 AM
  #963
noorj's Avatar
3-5 inhg? Not sure that's right
Old 12-02-2013, 09:50 AM
  #964
TStone's Avatar
It's cuz of the cams. He should hav a little more than that though
Old 12-02-2013, 10:08 AM
  #965
Tjolley's Avatar
I figured that.
Gona do a Lil investigating to see if i can find any leaks.
Old 12-02-2013, 10:30 AM
  #966
mrbelvedere's Avatar
im setting around 11inhg at idle check the evap connections and how high was it idling
Old 12-02-2013, 10:35 AM
  #967
Tjolley's Avatar
Im not running the evap its all capped off.
It was idling right at 800 were its set to
Old 12-02-2013, 11:50 AM
  #968
Tjolley's Avatar
valve cover 50
head traded value 250
supertech valves .5mm os 450
supertech springs and seals 450
folowers 75
lifters 150
GMR cams traded value 350
custom head gasket 210
ZZP GEN II girdled block 1750
gasket kit 75
custom wiseco pistons 575
total seal rings 210
trend performance wrist pins 125
eagle l61 rods 450
le5 crank 320
oil pan 50
block machine work 200
flywheel 350
clutch 650
1/2 arp head studs 250
ATI 400
arp flywheel bolts 100
gm main bearings 75 i think
clevite rod bearings 80
water pump 50
thermostat housing 50
this is majority of the list theres still alot of lil things to add
Old 12-02-2013, 12:15 PM
  #969
yea its low It could be in the tune also
Old 12-02-2013, 02:11 PM
  #970
KMO43's Avatar
I wanna get a 2.4 stroker for my lnf
Old 12-02-2013, 07:50 PM
  #971
Dude... 8K into the build... wow
Makes me look at the pricing breakdown i'm doing for my potential 2.1L hybrid and just realize that it's not nearly as expensive as I think
Mine will be quite stock though, nothing nasty like that.
Old 12-02-2013, 08:46 PM
  #972
noorj's Avatar
That's what I'm saying. Unless they really do have crazy overlap/duration
Trevor do you have adjustable cam gears?
Old 12-02-2013, 08:51 PM
  #973
its not a stroker its a 2.4 with an lsj head on it
Old 12-02-2013, 08:52 PM
  #974
kinda hard to use those when there is no spec sheet
Old 12-03-2013, 09:13 AM
  #975
Tjolley's Avatar
so now that i have a few miles on this 2.4. most everything seems good to go.
my oil cooler arives today so the car is going back in the garage to pull the front bumper off to mount this huge cooler and oil thermostat housing and lines to go with it all. new oil pressure guage and oil temp guage on the way
Quick Reply: stroker lsj build
