stroker lsj build
Old 10-31-2012, 03:23 AM
  #126
Haven07's Avatar
You are a crazy man scaring the **** out of us like this...
Old 10-31-2012, 07:57 AM
  #127
Tjolley's Avatar
lol...Im doin all this to try and hold this thing together..lol
i will be happy to get 10k miles out of this engine..lol
there will be more holes to drill lol. this is just the start..
Old 11-01-2012, 07:01 AM
  #128
Tjolley's Avatar
just a quick sample...what u think?
Old 11-01-2012, 09:25 AM
  #129
wayfarer's Avatar
can't judge a port on looks. Any flow data?
Old 11-01-2012, 10:13 AM
  #130
Tjolley's Avatar
nope Im doin this at my house...lol...hoping to get big nnumbers wen its done
Old 11-01-2012, 10:26 AM
  #131
mrbelvedere's Avatar
another numbers queen
Old 11-01-2012, 12:26 PM
  #132
armcclure's Avatar
under the curve ftw. litterally.
Old 11-01-2012, 12:55 PM
  #133
wayfarer's Avatar
yup. I don't like the "poke and hope" method of high performance engine building. I use micrometers and dial bore gauges instead of plastigauge. I use a weather station at the track instead of guessing. I use a flowbench to tell me if the modifications I make to the port increase or decrease airflow. I use wet flow to see if polishing a chamber leaves fuel puddles...
lots of people use wideband air fuel gauges to check numbers. people monitor IDC, and on and on.....I don't know jack about tuning, but a timing table is ALL NUMBERS
cars ARE math and science.
gut feeling has a place, and experience can't be ignored, but you can't automatically discount a "numbers approach"
assuming a port flows well, or sees an increase just because it's big and shiny is naive. I'd lay money he got gains with that port job, but how much? is the exhaust capable of keeping up? are there dead spots in the bowl or runner that he doesn't know about ?
a flowbench is a useful tool, just as a dyno is. Both can be helpful, or they can be just plain silly wastes of money and time. The information gleaned must be used properly or it's worthless.
Ultimately, you can't drive (or race) a flowbench or a dyno, but that doesn't mean they're bullshit.
Old 11-01-2012, 02:20 PM
  #134
Tjolley's Avatar
good info...
Most of use cant spend the money to buy that or pay some one to flow it...
Im just going with the numbers i have came up with...
the stock port inlet is tapered alot..
Old 11-01-2012, 02:26 PM
  #135
Tjolley's Avatar
Old 11-01-2012, 02:39 PM
  #136
wayfarer's Avatar
THAT ^^^^^^^^ is a REALLY cool picture of what's going on with the oil system!
Old 11-01-2012, 02:58 PM
  #137
carstedt's Avatar
great stuff here, keep us updated
Old 11-01-2012, 03:00 PM
  #138
Tjolley's Avatar
that's y i cut up a block lol
Old 11-01-2012, 03:13 PM
  #139
i never said flow beches were useless but to many people get hung up on numbers and every flow bench will always give you a different set of numbers so what do you believe that is why i dont take certian numbers as gosphel but on the lsj head you will never get an exhaust port to keep up with the intake(or even most heads the ex wont keep up) its just to dam small and any port modification on the lsj head will yield more airflow. just smoothing out and getting rid of the flash on the intake will yeild a 30cfm increase as for a numbers approach to a small point you can take it that way but just because it works great on paper dosent always mean it will work in real world conditions
Old 11-01-2012, 03:14 PM
  #140
SylverSS/SC's Avatar
Subbed for later!
Old 11-01-2012, 03:28 PM
  #141
lsjion's Avatar
Keep the port simple, dont do too much. good gains will be had, as long as you know what you are doing. Trust me, been porting lsj heads for a while now.
Old 11-01-2012, 03:54 PM
  #142
Tjolley's Avatar
yep...like i said the opening tapers alot
Old 11-01-2012, 04:00 PM
  #143
armcclure's Avatar
IMO flow bench shouldn't be used to preach numbers but to ensure consistency between ports. Your hands aren't a CNC.
Old 11-01-2012, 04:06 PM
  #144
1AJeremyD's Avatar
Any tips lsjion? Im not looking for a complete run down but any advice or possibly a push in the right direction on some good info?
Old 11-01-2012, 04:36 PM
  #145
Tjolley's Avatar
good point
Old 11-01-2012, 06:49 PM
  #146
wayfarer's Avatar
i never said flow benches were useless but you did insinuate it, and that I am stupid for asking for numbers but too many people get hung up on numbers and every flow bench will always give you a different set of numbers this is true, comparing numbers between machines has to be taken with a grain of salt so what do you believe you seem to believe that anyone who wants to talk about numbers is an idiot, and seek to squelch any sort of discussion on the topic that is why i dont take certain numbers as gospel as well you shouldn't. Like you said, every bench is different, but, so is every casting, every person who ports, and each individual port within a head but on the lsj head you will never get an exhaust port to keep up with the intake(or even most heads the ex wont keep up) but you can quantify the difference and work within accepted norms for percentage of flow, which have been established with decades of flowbench testing and then BACKED UP WITH REAL WORLD EXPERIENCE its just to damn small and any port modification on the lsj head will yield more airflow. I guarantee an amateur with a die grinder can modify a port and hurt flow and power production just smoothing out and getting rid of the flash on the intake will yeild a 30cfm increase cool! I'll keep that in mind when I work my head and quantify the changes on the flowbench! (thanks for the number mr. anti number guy!) as for a numbers approach to a small point you can take it that way but
just because it works great on paper doesn't always mean it will work in real world conditions this is absolutely true. taking a numbers approach will give you an idea of what you need on paper, but eventually you have to prove it on the pavement. sometimes you fail, but you fail less if you get educated first
give it a chance instead of trying to shut down / dismiss what could turn into an educational discussion
Old 11-01-2012, 07:37 PM
  #147
Tjolley's Avatar
this is very good info here...
lets not turn this into a war!!!
both have very good points..
Im doing this with wat i know and wat Im learning..
Im open to any help i can get..
and wen this build is over and i get the car on a few different dynos and some track time ill be making a new build thread with most of this info...Im keeping some of it under wraps..
Old 11-01-2012, 07:53 PM
  #148
TStone's Avatar
Originally Posted by Tjolley
good info...
I hope you weren't including yourself in the category "most of us" haha
Old 11-01-2012, 08:01 PM
  #149
Tjolley's Avatar
gona get it flowed cuz this build is all or nothing.
Im trying to give the m62 every chance it can get...lol
my hp goal with that on e85R. most will laugh at..that's y i haven't posted my dyno numbers from the build i have now...
Old 11-01-2012, 08:02 PM
  #150
lsjion's Avatar
Just get good stuff to port with. Thats all I can say. I gotta keep some job security.
Quick Reply: stroker lsj build
