studs/gasket
studs/gasket
Hey, just had a quick question about the ARP headstuds and cometic gasket. I know factory head bolts are torque to yield, and cant be reused, but can the ARP studs be reused? same question for the headgasket. I plan on building my head and my bottom end, but in all likelihood I will do so at two separate times, so it would be nice to know I wont need a second set of studs/gasket if i go about it this way. I;ll probably build the bottom end, and run that for a while, then ater build the head
