subaru sound of death question
Old 03-13-2012, 11:42 AM
mrbelvedere's Avatar
when you do a compression the guage has a check valve in it so pressure wont bleed of untill you push the button you should do a leak down test just because your engine shows good compression dosent mean it will pass a leak down test and you could have just had a plug go dead
Old 03-13-2012, 02:33 PM
SaberD's Avatar
i bet your spark plug backed out a little bit. I've had this happen to me on another car, and it caused missing and went rich.
Old 03-13-2012, 03:14 PM
06cobalt racer's Avatar
they were all still tight. i put the socket and extension on and tried to turn them by hand before i took them out and none moved.
Old 03-13-2012, 03:48 PM
SCcobaltSS's Avatar
coil pack possibly
Old 03-13-2012, 04:02 PM
here are the plugs, the are all still gapped at .035 which is what i set them at when i put them in. any thoughts?
number 1
Old 03-13-2012, 07:52 PM
SaberD's Avatar
here is a good website for reading your spark plugs.
NGK Spark Plugs USA
It appears to me that your plugs are dry fouled. Sounds like you should consult your tuner.
Old 03-14-2012, 12:02 AM
running rich
Old 03-15-2012, 07:51 AM
05vue-redline-06ion's Avatar
Originally Posted by mrbelvedere
looks like you had a detonation problem or an over fueling problem
10:1 and didnt get it tuned fast enough.....
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
Builttss
10-04-2015 10:21 AM
jimbofug007
10-02-2015 12:06 PM
Quick Reply: subaru sound of death question
