Supercharger oil?????????
I just went to the gm dealership this mournin to get some supercharger oil. They told me that it's all selfcontained??????? I thought I had read that you can fill them?????? Anyone, is this true???????
It sounds like the bearings need lube. I can hear them at idle if I put my ear down to the s/c.
Nope ....
If your coupler is getting noisy it may be time to change it.
The rotors make noise at idle to (which is perfectly normal).
Are you sure it's the bearings ?
i changed my s/c oil at 55k miles just for peace of mind. now im at 70k and no noises or nothing coming from blower. shes on a 2.7 pulley but has been on a 2.9 since 1000 miles. changed to 2.7 pulley at about 65k miles. changing oil on blower is cake.
Not necessarily. I read how many miles you had on another thread, so it most likely is a good thing to change anyway. You have to pull the s/c off when you change its oil anyway, so take a look at the rotors and see their condition. If the coupler is still noise after the oil change, you might as well change out the coupler for a new one. They come pretty cheap anyway, so if it were me, I would just replace it anyway.
I am dumb. I dont know everything. But if its suppose to have a noise, then imma leave it alone. I see my drain plug on my snout,thats why I asked them if they was sure it was completely sealed.
I just like to make sure my **** is runnin good and make sure if somethin sounds wrong, I fix it asap.
Last edited by wkindlesparger; 07-09-2010 at 12:01 PM. Reason: Automerged Doublepost
