Swapped Plugs Again! NGK vs Zex Pics!
Old 08-21-2007, 12:50 PM
lsjwannabe's Avatar
interesting
Old 08-21-2007, 12:52 PM
06blackg85ss's Avatar
iridiums are some what self cleaning too which always helps. My last set have been in the car now for a few months and look great. I'd post pics, but I haven't seen my car in over a week now.
CTCOBALTSSS's Avatar
Originally Posted by 06blackg85ss
they last a lot longer, my coppers only made it about a month or so, but car was running pretty rich at that point
My car is running rich right now too. That might explain the Zex plugs.
I'm trying iridium next. Probably right when spring hits.
Old 08-21-2007, 12:53 PM
lsjwannabe's Avatar
get that **** tuned
Old 08-21-2007, 12:54 PM
yeah Tony, when you swinging through for a retune now that you have a working wideband? need to lean that bitch out a bit
Old 08-21-2007, 12:55 PM
lsjwannabe's Avatar
what is the afr now?
Old 08-21-2007, 12:57 PM
Originally Posted by lsjwannabe
get that **** tuned
W3RD. It's tuned, it was just done with no wideband. Time to fix it.
I'm thinking maybe Saturday Sept 1st??
I'm down for any weekend except Sept 8-9th. A retune will make all the difference in the world.
I'm running a solid 10.2 at WOT, riiiiiich.
Old 08-21-2007, 12:58 PM
lsjwannabe's Avatar
yeah my car has been running like that in the top end to lately
Old 08-21-2007, 01:00 PM
yeah man that's no good. Getting some high egt's from that manm
September 1st sounds good man, just call or PM me a few days before to remind me lol. I'll get it nice and dialed in for ya, should have a nice increase.
Old 08-21-2007, 01:08 PM
lsjwannabe's Avatar
yeah i don't beat on the car much so im not to worried and if something goes its just a resaon to build stronger
Old 08-21-2007, 01:12 PM
  #36
Cool man sounds good. I'll call you the Thursday before or so. Thanks man.
We'll go get some beef afterwards.
Old 08-21-2007, 06:13 PM
  #37
sounds good
Old 08-21-2007, 08:48 PM
  #38
Jmc007's Avatar
Your car is running too rich plus the fact this Zex Plug is probably colder (too cold) than the BKR7E ? It might explain the black color.
Old 08-21-2007, 10:17 PM
  #39
That's what i'm thinking. Mr. Paul is going to fix the tune next Saturday. I can't wait.
Originaly I didn't have a wideband. We tuned it so there was no knock with a decent afr.
The hot temps don't help but what will help is a fine tune with this wideband.
BTW, Paul. What's your favorite beer?
Old 08-21-2007, 10:25 PM
  #40
06black's Avatar
adjust spark dwell with the zex plugs and you'll be happily surprised at the outcome.
Old 08-21-2007, 11:29 PM
  #41
madeinUSA's Avatar
i have had good success with copper autolites
I really liked the Autolite 23s that I ran in my G.N. (Grand National for you young'uns) What is the part# that you run in the LSJ?
Old 08-22-2007, 08:54 AM
  #42
You want these. Autolite LSJ-ASP-3922
Go here and click on Store then GM 2.0L then electronics.
http://www.intense-racing.com/
Old 08-22-2007, 09:08 AM
  #43
R&C_rallySS's Avatar
This is a good thread, I only have 8k miles on my car so I'm sure I don't need plugs yet. However its good to know what to do when the time comes. With my mods I was told not to go with colder plugs. I'm still running the stockers. Would the car run any differantly if I change from the stockers to something else? And if it will run better can you tell me why?
Old 08-22-2007, 09:20 AM
  #44
Yes you should swap out your plugs. With those mods I would.
Go with NGK iridiums or copper plugs. My car likes the copper NGKs.
You want to run one step colder plugs with smaller than stock pullies and supporting mods.
This pretty much explians it.
Do I need a colder spark plug? A rule of thumb is one heat range colder for every 45–100hp you increase. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber. The heat range numbers used by spark plug manufacturers are not universal, so a 10 heat range in Champion is not the same as a 10 heat range in NGK or in Autolite. When making the decision to change the heat range of your plugs, it is a wise idea to make changes in 1 heat range increments, checking all your plugs for suitability during your test. Vehicle modifications during the test phase of your plugs is not recommended as this may skew your results.
Old 08-22-2007, 09:42 AM
  #45
lsjwannabe's Avatar
nice post ct
Old 08-22-2007, 09:46 AM
  #46
nice post ct
Thank you sir.
05-28-2022 03:47 AM
dennis69
10-20-2015 04:49 PM
10-13-2015 09:32 PM
ThoR294
10-04-2015 08:44 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: Swapped Plugs Again! NGK vs Zex Pics!
