TEASE :Ljavy's Parts waiting to be installed.
Old 03-19-2007, 12:57 PM
Doc
Doc's Avatar
The best part....you don't know how to install the parts you have... j/p
Old 03-19-2007, 01:07 PM
06blackg85ss's Avatar
The throttle body spacer mounts btwn the s/c and the throttle body, shoulda came with longer bolts too. Hopefully since you got the whole kit with the spacer, the solonoid valve should be in the package. (very simple to install just run power lead in line with lead to pump, and ground other wire) I would recommend the 275ml jet and leave the settings on the controller to 1 across the board to start (I think I used 0 but it's been awhile)
but if you are using the spacer def make sure you install the sol valve, or else you'll flood your motor out the second you start the car. I got to learn that the hard way.
and btw... you still haven't installed this yet? goddamn man. I'll be doing an install on Mezzano's car this sunday (meth, front mount H/E, 2.6 pulley, 60lb inj, and custom tune) so if you don't have it on by then, I'll put up some pics of the install
Last edited by 06blackg85ss; 03-19-2007 at 01:07 PM. Reason: Automerged Doublepost
Old 03-19-2007, 03:39 PM
BravoPuma6's Avatar
Lazaro, lets install it on wensday?
Old 03-19-2007, 03:43 PM
Ljavy17's Avatar
SHUTTYUP!
okay so what does the SOl valve look like. I got the whole kit with the longer bolts and all.
Old 03-19-2007, 03:47 PM
pm replied
Supercharged06SS
12-11-2022 04:47 PM
10-20-2015 09:56 PM
justinchinn
10-02-2015 12:18 PM
dieGone
10-01-2015 06:27 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: TEASE :Ljavy's Parts waiting to be installed.
