Test pipe vs catless downpipe?
I was going to get a 2.5 catless dp fabbed up at a local muffler shop and the guy said the restiction is most likely only in the cat, and that a test-pipe should give me nearly the same results. Can anyone confirm this?
No... by test pipe I mean taking the dp off, cutting off ONLY THE CAT, and then welding in a section of pipe. Still using the rest of the stock piping, still using the stock flex pipe and flanges. Sorry if I wasnt specific enough.
oh, my bad. No the restriction isn't JUST the cat. Did he take a look under the car? If he did, he wouldn't have said that. There's a huge pinch in the stock DP where it bends to go to the rear of the car. That's also where the o2 sensor is. You need a whole new DP to see the best gains. Make sure the piping they do is Mandrel bent, NOT PRESS BENT. 2.5" dp is perfect.
I'm sure my stock cat is half-clogged allready from this pig-rich stage 2 tune. Unless I can get the local shop to fab me a dp/header combo, this seems like the best idea for now.
A test pipe is a bolt on cat delete as far as I know; you replace the test pipe with your cat for emissions then take it off after passing. The only problems with a test pipe is the possibility of flange leaks but if your welding that's not an issue. If you cut where the o2 bump is then it would probably be cheaper and a decent but loud upgrade.
I have no cat.. with a 3" dp... get a resonator welded in.. its the best thing you can do and it makes 85% of that raspy sound to go away (it did on my setup anyway... and not exaggerated)
The thing your thinking of where the pipe stops is a exhaust cutout... Very loud and wont do much for 4 bangers.
test pipe are pipes straight back.. nearly no bends (if possible) w/o a cat...
Not thinking of a cutout, just cat delete as neelster said. I dont want to order a dp, beacuse I dont order things online. I dont have a credit car and I dont want to connect paypal to my bank account(paranoid). How much should a resonator small enough to be welded into my dp cost and would a normal muffler shop sell it? What kind of raspyness would I expect from a cat delete? I know hollowing it out is supposed to sound like ass, but is it that bad if I just put weld in a section of pipe the same size as the rest of my exaust?
I'm too JDM for you
its really not that bad.. ill record my audio and send it to you
i got a 18 or 20 inch resonator welded in for 70 bucks.... You will expect ALOT of raspyness unless you get the resonator... It will sound just as bad... and im telling you.. the resonator is AWESOME.. you have no idea how much this helped me.. i really didnt expect it to do what it did... thats seriously how much it helped..
I'm too JDM for you
bBw, what kinda cel's will I get and how can I get rid of them wihout hptuners. I know a scantool will clear them but unless I get sometrhing to trick the sensor it'll just pop right back up right?
Sure will.. To be honest i dont even have my 2nd o2 sensor hooked up.... And hptuners and one other thing i think will clear it... you can kinda trick it by using some washers and such.. but it only sometimes works...
So you unhooked your 2end sensor? Will that work even without hptuners? I dont want to tune my car unless I get a 2end ecu to tune and keep my stock one for warranty; and what does everyone mean by raspiness? anyone have a video to show me what it sounds like?
I'm too JDM for you
the code will just keep coming back everyday...i have gotten so used to the check engine light that it doesnt bother me. if you want, go to your auto parts store and get 2 spark plug anti-foulers and screw them together. now drill out the center a little bit so the o2 sensor can screw in. you have a good chance of this not triggering the CEL
Does the stage 3 ecu get cel from this too? Since its " for off-road use" according to gm, would they have designed it to throw a code for that? I'm thinking about buying one soon.
