Thinking about OTTP stage 3 kit...
Old 06-14-2010, 03:45 AM
Killa702's Avatar
so if i run meth i dont need e85? thats good lol
with the mods i previously posted would i be able to run 2.8?
Old 06-14-2010, 03:49 AM
G85 SS's Avatar
To run the 2.8 on the TVS safely I'd say you should use the CTI race header/3" downpipe to a 3" catback exhaust.
If not EGT's will skyrocket.
Also, some 79lb injectors will be needed. 60's will not be able to keep up with the airflow the TVS produces.
Everything else you should be good.
Old 06-14-2010, 03:57 AM
Killa702's Avatar
wouldnt the vibrant header be good also?
Old 06-14-2010, 04:19 AM
G85 SS's Avatar
I don't know what the primaries are and also I think Vibrant is 2.5", not 3".
I could be wrong on that.
You're gonna want 3" all the way. The more air you shove into the motor, the more air you wanna be able to get out.
Old 06-14-2010, 04:23 AM
Killa702's Avatar
oh i see, makes sense
i just wanna be able to run 2.8 safely without blowin anything
G85 SS's Avatar
Actually. Scratch the vibrant/CTI deal.
OTTP's longtube header is the route I'd go now.
Old 06-14-2010, 04:27 AM
Killa702's Avatar
http://www.ottperformance.com/store/pc/Headers-c22.htm
the longtube doesnt come in 3" tho
Old 06-14-2010, 04:35 AM
G85 SS's Avatar
Because it's primaries all the way to the collector(just prior to the v-band flange).
The v-band outlet you can get in either 3" or 2.5".
Primaries come in 2 different sizes. If you get the 1.75" primaries you'll be more than golden on a 2.8 pulley with the TVS.
I'm telling you, that longtube header is the best header on the market by far.
And extremely well craftsmanship.
Old 06-14-2010, 04:38 AM
sundevil07's Avatar
just run the meth! i run/ran 75/25 with a hint of smurf jizz
Old 06-14-2010, 04:40 AM
Killa702's Avatar
whats so good about the longtube? cause ive herd it is good
Old 06-14-2010, 04:49 AM
  #36
G85 SS's Avatar
I have seen proof of said smurf jizz.
I don't know all the pro/cons of it.
All I do know is that for bigger builds(IE TVS) or something that flows a lot of air, longtube is the way to go.
Old 06-14-2010, 04:55 AM
  #37
Killa702's Avatar
alright thx, so once again longtube header, ottp h/e, 3" megan exhaust, meth.
id be safe runnin 2.8 with all that ^?
im not sure if my exhaust is 3" tho imma have to measure it
Old 06-14-2010, 05:06 AM
  #38
G85 SS's Avatar
Megan racing exhaust is 2.5".
Hahn and CTI make 3" exhausts.
I don't know of any others.
You can get a custom mandrel bent exhaust if you want.
All of that is "safe" if tuned properly.
Old 06-14-2010, 05:10 AM
  #39
Killa702's Avatar
wait so what would i need to do for my exhaust to fit the three inch header? cause i dont wanna buy a new exhaust
Old 06-14-2010, 05:52 AM
  #40
G85 SS's Avatar
If you don't want to buy a new exhaust you might wanna just pass up on the TVS with 2.8
You'll choke it out and end up losing power.
But to answer your question, from the v-band, you can get the 2.5" adapter. That'll bolt up to your current exhaust.
Old 06-14-2010, 05:53 AM
  #41
Killa702's Avatar
if i get the 2.5 adapter can i still run the 2.8?
Old 06-14-2010, 08:30 AM
  #42
mrbelvedere's Avatar
killa you dont comprehend things very well do you you can run wat ever pully you want
you can run strait meth to and you add the water to help absorb the heat from the blower not to make the meth a little safer there is some missinformation in this thread
and you dont need a ******* race header to run a tvs either a cia or zzp header is more then sufficant
Old 06-14-2010, 11:06 AM
  #43
Killa702's Avatar
thnx
05-28-2022 03:47 AM
06MetallicBalt
08-17-2021 03:40 PM
biniecki
10-25-2015 02:23 PM
SSLOW06
10-01-2015 07:21 PM
09-26-2015 06:44 PM
Quick Reply: Thinking about OTTP stage 3 kit...
