For those with GM Stage 3
Old 03-14-2008, 11:26 PM
  #101
rockkrawler628's Avatar
Originally Posted by RoelSS
With the GMPP Stage 3 ECM, you won't get a CEL for a catless downpipe!!
yes, I knew that. but that doesn't answer my question.
My question is does it pass emissions when i take it in for emissions and inspection? I don't need to know about inspection just emissions..
Oh yeah... And don't shout at me roel... its not nice.
Old 03-15-2008, 01:10 AM
  #102
badboylb32's Avatar
im curious about something....with a cai like injen of fujita wouldnt that make the car run even leaner thus more dangerous to run with a 50 shot+stage 3..and wouldnt it make the injectors max out even more to compensate for the extra air?.i seen roelss afr on that dyno and it was cutting it a little close but he just has a drop in filter....sorry about the thread jack dude but ill be getting stage 3 soon and i think it might be safer with just the stock intake...and i didnt want to start another noob thread....
Old 03-17-2008, 09:57 AM
  #103
RoelSS's Avatar
According to GM it's not meant for emissions because it considered an OFF-ROAD product. So more than likely, it probably won't. By the way, i'm not shouting at you, It was more a good thing because you don't get a check engine light. (Like a Homer Simpson, 'Whoo Hooo!) Sorry about that.
Yeah, thats why I put the stock intake on, since GM did design the kit around a stock intake. Any aftermarket intake will make your car run leaner. I was actually thinking about putting the paper filter back in, it will probably fix the AFR's. Besides, it's easier to drill the hole on the rubber/plastic intake vrs drilling and sealing on a metal/aluminum pipe.
Old 03-17-2008, 12:28 PM
  #104
[QUOTE=RoelSS;2085375]According to GM it's not meant for emissions because it considered an OFF-ROAD product. So more than likely, it probably won't. By the way, i'm not shouting at you, It was more a good thing because you don't get a check engine light. (Like a Homer Simpson, 'Whoo Hooo!) Sorry about that.
lol alright thanks man
Old 03-17-2008, 01:13 PM
  #105
BCobaltSS's Avatar
I was wondering this . Can I tap the Kand N intake on mine to run the nitrous. Will it run that much leaner if I run nitrous... I was hoping not to take it out but if it is a mater of frying a piston then I wil switch back.
Old 03-17-2008, 02:03 PM
  #106
RoelSS's Avatar
From way back when the cold air intakes 1st came out, I remember some people were getting CEL for lean conditions. Since GMPP stage 2 is runs richer, some people didn't get that CEL. I didn't want to risk it. I used to have the $200 k&n typhoon, sold it for $140 and used the funds towards stage 3 instead. You can always do the air box mod too, but I don't know how the engines AFR's will respond.
Old 03-17-2008, 02:48 PM
  #107
BCobaltSS's Avatar
hmm interesting I will try it with the Kand N intake and let you know . Saving right now for the dyno tune dry shot kit. I never got a code for running too lean . Just fitment issues. Plus I heard that it was too much oil on the filter that got onto the MAF that threw a code
Old 03-17-2008, 03:21 PM
  #108
badboylb32's Avatar
cool man thanks....ill be waiting
Old 03-18-2008, 12:04 AM
  #109
same here
Old 03-25-2008, 02:22 PM
  #110
Originally Posted by CBodnar
all i gotta say is ur mad smart rockkrawler for buying 42.5lb injectors then just buying stage3 kit or whatever. i wish i thought of it cause i would of taken that route. way to save money! i love being a superjew and saving money when ever i can. more power to ya
lol i wish my test grades shown that
How much would we benefit from removing the stock A/C condenser?? Since stage 3 removes the capabilities of A/C I figured hell, Why not just remove the A/C condenser? How hard is it to do this??
Also I've been doing some searching but does anybody know how much better will it be to run 60/40 water/coolant in the summer time and possibly some water wetter or something?? And will you actually hafta change out a 60/40 mixture for the winter? During winter I see temps below freezing
Last edited by rockkrawler628; 03-25-2008 at 02:34 PM. Reason: Automerged Doublepost
Old 03-25-2008, 05:38 PM
  #111
207GT04's Avatar
Here is Florida I know alot of guessing running straight water.... I really would like to run straight water wetter through it but it would be like 100 bucks in that stuff.... I didn't even spend that to install the cobra! I don't know if any performance gains is really seen running the wetter but every little bit helps im sure The stock AC condenser is the closest to the engine and is connected to everything else (radiator, stock intercooler) by a special GM connector piece. The bumper will have to come off for sure to get it out... Hope that helps.
Old 03-25-2008, 08:49 PM
  #112
alright... thanks
Any body else with info on what the best mixture is for the intercooler and engine cooling system? I'm thinking about running 60/40 water/coolant but idk how that would hold up in winter if i'd hafta change it out or not... it gets a little below freezing here.
Old 03-25-2008, 09:25 PM
  #113
Sergio's Avatar
The best coolant on earth is pure water. Use that with one dose of water wetter and you'll see some nice gains.
Too bad water freezes, so this is a summer only thing for sure. Are you hardcore enough to change coolant twice a year?
Old 03-25-2008, 09:28 PM
  #114
we'll im worried about running straight water... even if i've got a can of water wetter in... I'd Like to go with 60/40 water/coolant but idk how much of a cooling difference there will be.. the reason i ask is because i'll have stage 3 in a couple of days but i have no cooling mods... changing out coolant is the cheapest route to go
Old 03-25-2008, 09:41 PM
  #115
hungryhip-ccp's Avatar
pm'd
Old 03-25-2008, 09:50 PM
  #116
hungryhip-ccp... even though i didn't get the pcm i ordered from you yet (since i only ordered it yesterday, lol) but i wanna say hungryhip is cool as ****... he shiped my stuff right away and didn't fck around and answered all my questions... not the usual short as answers either which leave me asking more and more questions but he answers being long and detailed. thanks alot man
Old 03-26-2008, 01:02 PM
  #117
BeermanSSSC's Avatar
Is hptuners trying to hack the stage 3 ecu yet? I really want to go stage 3 but I need a/c in arizona, i think i would die in the summer without it
Old 03-26-2008, 01:26 PM
  #118
007Buff's Avatar
60/40 water to coolant is fine in cold winters
Old 03-26-2008, 01:36 PM
  #119
Does anybody know if the stage 3 ecu has the fans come on earlier then stock? I know some of the things stage 3 does but don't know the actual settings.
Old 03-26-2008, 01:44 PM
  #120
turboeco's Avatar
I have a 05 stage3 PCM for sale, $285 shipped.
and there is a how-to by mcwarren, that tells you how to hook AC back up.
Old 03-26-2008, 04:00 PM
  #121
RoelSS's Avatar
No, they come on at the same temps.
Old 03-26-2008, 04:06 PM
  #122
damn... alright thanx man
Old 04-05-2008, 02:37 PM
  #123
How much will Stage 3 increase my Gas mileage? As it is more lean then stage 2. I get around 24 mpg now when driving to school... driving home from school i avg. around 20 lol you can tell im not in a rush to get to school
Old 04-05-2008, 04:11 PM
  #124
stock as far as i know... my car even in drive threw's the fans never came on and temps never went above like 202 or 207 in the middle of the summer in traffic i think they came on once gotta love the aluminum block and head almost like one big radiator
i saw a deffinate increase in milage over stage two i was seeing like 20-24 city and like 30-32 hwy with stage three i saw as much as 28 city and 37-38 hwy but i think this mainly had to due with full exhaust as well h, dp, 3" thats were i saw a huge increase in performance and milage... hope this helps some... by the way hows she running now that youve recieved my stage three?
Last edited by hungryhip-ccp; 04-05-2008 at 04:11 PM. Reason: Automerged Doublepost
Old 04-05-2008, 06:05 PM
  #125
sweet... thats insane.
As for installing the stage 3... i havent yet due to warranty reasons... the dealership made me take my mounts and **** off cuz they think thats what was causing my screeching at idle. I personnaly think its the timing chain since my build date is in the middle of when GM had the issue with non heat treated chains. Who knows.. I'll post a thread about it since i'll be installing Stage 3, belt, injectors, old motor & trans mounts, and possibly a downpipe if the member ever gets back to me about it.
Quick Reply: For those with GM Stage 3
