For those with GM Stage 3
Old 03-21-2009, 09:00 AM
  #201
blownredSS's Avatar
Yea, its been talked about, and I know it has been done, but no mention of what nozzle or mixture was used to achieve it.
Old 03-21-2009, 04:07 PM
  #202
hungryhip-ccp's Avatar
Originally Posted by Try2k
Meth will work with 100 octane mode, you just have to have the right mixture, nozzle and boost level where it starts to spray. ccp and I have both done this.
agreed!!! it all in the set-up and the nozzle size
ok, it worked for me all summer long in '07
this was my set-up,
cai, ported tb blower inlet, dual pass, stage 3 pcm, zzp shorty header, zzp 3in catless dp, 3in custom magnaflow exhaust.
AIS methenol kit non progressive, line pressure at 160-175 pump turned all the way up from ais, 6gph nozzle located in a tb spacer (<---very important) 75-80% pure M1 methenol with distilled water.
Last edited by hungryhip-ccp; 03-21-2009 at 04:09 PM. Reason: Automerged Doublepost
Old 03-22-2009, 12:25 AM
  #203
blownredSS's Avatar
Thanks for the info, did it make much of a difference using the 100 Mode versus 93? I'd like to know if I'm wasting my time for a minimal gain.
Old 03-22-2009, 02:02 AM
  #204
it was much more aggressive in the lower end. which was quite fun!
Old 03-23-2009, 12:52 PM
  #205
BCobaltSS's Avatar
anyone done S3 with 100 octane tune "on" and then hit the nitro? What did that feel like?
Old 03-23-2009, 03:20 PM
  #206
ShortStack's Avatar
My guess is lots of fun lol...
Old 03-24-2009, 11:16 PM
  #207
SlyderRE's Avatar
Question. i have a gm stage 2 pulley, belt, and inj. i might be getting a stage 3 ecu, can i install all these parts with no problems? do i need to do a crank relearn and what is that? my current mods are in my sig
bump for an answer
Old 03-24-2009, 11:22 PM
  #208
Pyros777's Avatar
I didn't need to do any sort of relearn when I installed my Stage 3 PCM. It was 100% plug and play.
Old 03-25-2009, 03:04 PM
  #209
same here.
Old 03-25-2009, 05:57 PM
  #210
SlyderRE's Avatar
aite guys, thanks
Old 03-25-2009, 06:29 PM
  #211
blownredSS's Avatar
I unhooked the battery then put the PCM and hooked it back up, no probs.
Old 03-25-2009, 06:39 PM
  #212
SlyderRE's Avatar
k cool. gettin the ecu friday, might install my pulley, injectors and ecu on saturday, maybe monday
Old 04-29-2009, 03:35 PM
  #213
RoelSS's Avatar
Originally Posted by distillion
I bought a zex kit. (Dry)
as long as you have arm switch and the proper wiring setup your good.
Im just wondering if people are running the stock plugs when they are spraying.
Very late response, but Yes, stock plugs on spray. The engine bogs and hesitates with others.
Old 04-30-2009, 07:38 AM
  #214
distillion's Avatar
noticed that even without spray.
got the stockers in for a while now and runs perfect.
Old 04-30-2009, 10:03 AM
  #215
RoelSS's Avatar
x2. with or without spray. Stockers work best.
Old 04-30-2009, 11:44 AM
  #216
ecotecon18s's Avatar
YELLERCOLT just ran a 13.5 with Stage 3 PCM, 100octane mode on, the nitrous, CAI, and 2.8 pulley all on street tires. that was this past sunday.
Old 05-04-2009, 02:25 PM
  #217
RoelSS's Avatar
What was the MPH?
Old 05-04-2009, 06:50 PM
  #218
106ish...
he also ran 8.3 @ 83mph in the 8th a while back with only stage 2, intake, and slicks.
Old 07-26-2009, 01:24 PM
  #219
bandit's Avatar
airconditioning
does any one kno how to bypass the a/c with gm stage 3 pcm so the airconditioning still works i have heard u have to jump a ground wire?????
Old 07-27-2009, 10:37 AM
  #220
Pyros777's Avatar
^ here you go:
GMPP Stage 3 with A/C
Old 07-27-2009, 12:56 PM
  #221
BCobaltSS's Avatar
Really .... only a 13.5. Does he have any traction mods ? I heard of guys getting 12.9's on this setup . Must be with only drag slicks then .
Old 07-27-2009, 05:29 PM
  #222
bandit's Avatar
hey man thanks for that link means a lot been looking for ever
Old 07-29-2009, 11:04 AM
  #223
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by mrniceguy8211
Installed my stage 3 pcm yeasterday. What a difference, Def. worth it. Thank you Turboeco for the fast shipping. Car runs ALOT better now that with the Stage 2 Pcm.
you mention the car runs "ALOT" better with the GMS3 ECU then it did with the GMS2 ECU .... did you install the Stage 3 ECU at the same time you dropped down to the Stage 3 76mm pulley ?? if so, thats why the car felt like it ran better. I have the 07' GM Stage Tune, and when i dropped down to the Stage 3 pulley from the Stage 2 pulley my car felt like it ran a lot better. If this is is not the case, I'm very interested in learning more about the GMS3 ECU.
people say it runs leaner than stage 2, but is that when the high octane mode or nitrous mode is engaged ?? it is to my understanding that the GMS3 tune is identicle to the GMS2 tune when you arent running high octane mode or nitrous.
Old 07-30-2009, 10:13 AM
  #224
distillion's Avatar
the 93 tune stage 3 offers and the Gm stage 2 tune are different....
The stage 3 tune is more agressive, Timing, etc, smoother, and leaner at wot.
Old 07-30-2009, 10:20 AM
  #225
Administrator
Administrator
Staged07SS's Avatar
ok thanks ....
i have to clarify this though .... there is no GM Stage 2 Tune. GM Stage 1 & GM Stage 2 come with the same tune .... So really there is the GM Stage tune for Stages 1 & 2 & the GM Stage 3 tune. I know its easier to just call it the GM Stage 2 tune, but when new people come on here they get confused by the diff. tunes out there.
Quick Reply: For those with GM Stage 3
