For those with GM Stage 3
#202
ok, it worked for me all summer long in '07
this was my set-up,
cai, ported tb blower inlet, dual pass, stage 3 pcm, zzp shorty header, zzp 3in catless dp, 3in custom magnaflow exhaust.
AIS methenol kit non progressive, line pressure at 160-175 pump turned all the way up from ais, 6gph nozzle located in a tb spacer (<---very important) 75-80% pure M1 methenol with distilled water.
Last edited by hungryhip-ccp; 03-21-2009 at 04:09 PM. Reason: Automerged Doublepost
#207
Question. i have a gm stage 2 pulley, belt, and inj. i might be getting a stage 3 ecu, can i install all these parts with no problems? do i need to do a crank relearn and what is that? my current mods are in my sig
bump for an answer
bump for an answer
#219
airconditioning
does any one kno how to bypass the a/c with gm stage 3 pcm so the airconditioning still works i have heard u have to jump a ground wire?????
#221
Really .... only a 13.5. Does he have any traction mods ? I heard of guys getting 12.9's on this setup . Must be with only drag slicks then .
#223
people say it runs leaner than stage 2, but is that when the high octane mode or nitrous mode is engaged ?? it is to my understanding that the GMS3 tune is identicle to the GMS2 tune when you arent running high octane mode or nitrous.
#225
i have to clarify this though .... there is no GM Stage 2 Tune. GM Stage 1 & GM Stage 2 come with the same tune .... So really there is the GM Stage tune for Stages 1 & 2 & the GM Stage 3 tune. I know its easier to just call it the GM Stage 2 tune, but when new people come on here they get confused by the diff. tunes out there.
