throttle body
#52
^^ Yes if you don't port the blower inlet, and just use a spacer, you are still restricting the intake and not getting the full gains of the mod. The spacer might be bigger, but the air will hit a 3/8" lip on the bottom of the inlet of the SC, negating some of the gains. An air die grinder and a dremel go a long way...
#54
so what is the part number for this thing?
nvm found it on said website... 156 and change. Not too bad. Sure I could find one better at a junkyard.
Last edited by BoostedYards86; 11-30-2008 at 07:38 PM. Reason: Automerged Doublepost
#55
I would say buy used, much cheaper. It came on a lot of different applcations. Check the thread I posted above for a lot of info on it including a list of possible applications to aquire it from...
Here... https://www.cobaltss.net/forums/how-guide-43/how-install-big-bore-throttle-body-cheap-78653/
