throttlebody help....
Hey i was driving the other day and my car went into limp mode and i get these two codes....
[PCM] P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance (SES) (Pending) (History) (Immature)
p2101 throttle actuator control motor circut range/performance
anyone else have these problems???
check if it plugged in. make sure it's clean and if that doesn't work replace the tb. I had to replace the tb. Then the car was fine and finally could get full boost.
thanks for all the help guys. The problem was actually with the pump for the liquid to air intercooler. I put a terminal into the fuse box in a spot that had power with key on only and for some reason it was messing with the circuit to tell the throttle body what position to be at.
