Time to go turbo
first do a lot of searching and figure out what goes into making your own setup. a lot of things are determined on your power goal, like injector size and turbo size. once you figure that out, start looking for a manifold and turbo that fit your needs, then figure out if u wanna run the stock heat exchanger or go front mount. you will save a good amount of money and time just piping the turbo into the stock intake manifold and running the stock cooling system. once all that has been decided you can start buying the little things. good luck. im not gonna go into any more detail because all of us here want you to learn on your own.
09BlkCrusader
09-09-2015 04:47 PM
