Timing chain kit dnj reviews
Old 06-06-2016 | 09:24 AM
KobaltSC's Avatar
Hi so I'm about to change my main timing chain. Also the balance shaft set. I got the cloyes main set cam gear bolts ect, but can't find the balance shaft set(cloyes).Dnj makes chain, gears and tensioner for balance shaft just not sure of the quality. If anyone has had any experience with them how where the quality of parts in your eyes thanks alot. I search in main bar dnj didn't find much thanks agian
Old 06-06-2016 | 10:30 AM
taytoe's Avatar
I used non-oem timing/balance kits on mine back a couple months ago and had no issues I got the Sealed Power versions through Rock Auto, I looked into DNJ but couldn't find enough info to make the $20 savings worthwhile, it was $140-ish CAD for the balance set.
The only problems I ran into were on the timing set, water pump and crank cogs were for a N/A application.
Old 06-06-2016 | 12:25 PM
KobaltSC's Avatar
Alrighty that's where I was planning on ordering from aswell. I seen them too but wasn't sure about that set aswell thanks for response did u just reuse the guide bolts or did you upgrade?
Old 06-06-2016 | 01:04 PM
taytoe's Avatar
It came with the guides and bolts, didn't bother stepping up to ARP or some of the upgrade options out there since it's pretty stock. Guides and bolts were perfect fit and the chains seemed like decent quality comparing with the OEM design.
Old 06-06-2016 | 01:42 PM
Viperoni's Avatar
This would be a good opportunity to delete the balance shafts...
Old 06-06-2016 | 06:43 PM
ItalianJoe1's Avatar
I've used the DNJ stuff on other engines and it's fine, cheap stuff but no different than any other aftermarket option IMO.
Old 06-06-2016 | 06:56 PM
KobaltSC's Avatar
Sounds good thanks for input thinking I'm gunna go ahead and order it and the upgraded bolts. And viperoni i was thinking that but it's my dd atm any negatives to the no balance shafts are engine vibes bad. as long as it would still be reliable I'd like to the remove the extra rotating mass I'll do a bit of searching
Old 06-07-2016 | 07:40 AM
Staged07SS's Avatar
Administrator
Administrator
The vibes are minimal.
Old 06-07-2016 | 02:12 PM
KobaltSC's Avatar
Yea I was reading that also seems like a bit of work Im might do it over winter when I park it. I'm just doing chains because of higher km no failure, so won't be a big deal to take back apart again if I decide to go that route thanks again
Contrastic
06-19-2016 07:20 AM
2010CobaltLTfan
06-18-2016 05:34 PM
Dawatkinss
06-04-2016 08:59 PM
mikeluis92
06-02-2016 10:14 PM
mongorat427
05-18-2016 02:23 AM
Quick Reply: Timing chain kit dnj reviews
