timming for a 2.6 ring
Old 01-08-2009, 09:57 PM
Rent me! per hour
Area47's Avatar
i have traded peak horsepower to the tire for an ass load of torque. 10+ftlb difference on the curve and under it is worth a lot more to me than 3 peak hp diffenece
Old 01-08-2009, 10:04 PM
HOT CARLS SS's Avatar
So Area running the 45 Degrees of Timing at part throttle gives you 10f tq extra...?? Is that with meth? Your car must come on strong at the low rpms....what rpm does your timing change from 45 degrees too mid 20's
Torque wins races ----- Horsepower sells cars
Old 01-08-2009, 10:12 PM
jeanbalt's Avatar
torque = fun
hp = bragging right
Old 01-08-2009, 10:28 PM
Rent me! per hour
Area47's Avatar
newp. my part throttle timing is set for gas mileage. nothing more. wot timing however is ment for a broad powerband vs peak hp.
my car drops to mid 20's over 10psi. i have spent a lot of time on my timing tables. almost 2 years of work actually. which is why im very apprehensive on giving them out
Old 01-09-2009, 09:00 PM
How much timing can you run down low when not in the boost?? I think I am at 16 degrees???? not sure
Old 01-09-2009, 09:09 PM
Rent me! per hour
Area47's Avatar
part throttle. below .52 im assuming?
Old 01-10-2009, 01:48 PM
yes below .52...How much timing can you run when the car isn't in high boost say...5psi or less at part throttle?
Old 01-10-2009, 01:54 PM
Rent me! per hour
Area47's Avatar
well over 30
05-28-2022 03:47 AM
HEATON
10-16-2015 07:21 PM
Builttss
10-04-2015 10:21 AM
SlowSaturn
09-28-2015 11:03 AM
n20saturn
09-17-2015 01:55 AM
Quick Reply: timming for a 2.6 ring
