Tjolley's stroker LSJ
Old 01-04-2014, 07:42 AM
  #101
Tjolley's Avatar
oh and it starts missin wen the engine is warm
Old 01-04-2014, 09:38 AM
  #102
mrbelvedere's Avatar
do a plug reading
Old 01-04-2014, 09:50 AM
  #103
Tjolley's Avatar
Originally Posted by mrbelvedere
do a plug reading
i pulled the first set they were all burnt. im sure i cauzed that while tuning the car.
put new ones in it the other day. hopin that would fix it. it still dose the same thing.
mrb u ever see a coil stop working wen it gets hot??
Old 01-04-2014, 10:50 AM
  #104
South Central *********
JapEatr's Avatar
Yes.
I think your compression is too high
Old 01-04-2014, 11:40 AM
  #105
yes I have but post a pick of the plugs
the dynamic cylinder pressure(40to1 or more dynamic and on a cold night 50 or more could be possible) could be causing you problems it may be to much for the stock ignition system a 9.5to1 would be high 20s to low 30s dynamic on a 2.6 tvs
Old 01-04-2014, 11:55 AM
  #106
Tjolley's Avatar
ok ill pull the one in the car out. they have only been idleing
Old 01-04-2014, 11:57 AM
  #107
post the old plugs
Old 01-04-2014, 12:01 PM
  #108
Tjolley's Avatar
Originally Posted by JapEatr
Yes.
y would it suddenly start doing it then.
ill put a standalone ignition system on it if i have to
Old 01-04-2014, 12:02 PM
  #109
the higher the cylinder pressure the harder it is to fire the plug
Old 01-04-2014, 12:06 PM
  #110
Tjolley's Avatar
post the old plugs
ill have to pull them out of the garbage.
not much to look at but black plugs. lol
Old 01-04-2014, 12:10 PM
  #111
Tjolley's Avatar
i understand that.
i honestly dont think its compression related.
from wat msd told me we i was tryin to get them to make us upgraded coils they said our ignition system is set up really well and they recomened going aftermarket standalone for any real benifit over the stock setup.
Old 01-09-2014, 08:33 PM
  #112
The Red Ferret's Avatar
In for numbers. Also troll for info and hardly ever post.
Old 01-09-2014, 08:58 PM
  #113
ThexGovenor's Avatar
Keep us posted.
Old 01-10-2014, 03:26 AM
  #114
Dart_SI's Avatar
i need to start coming on here more. miss the old days.
Old 01-10-2014, 07:28 AM
  #115
Tjolley's Avatar
forgot about were i left this thread. lol
got the problem solved. ended up being a coil. i put a spare one in and its all good now.
i got stupid busy at work and its gona stay thay way for a while. been working 14+ hr days.
Old 01-10-2014, 09:44 AM
  #116
good for you man, get that overtime!
Old 01-24-2014, 11:52 AM
  #117
Still running with no problems?
Old 01-27-2014, 09:02 PM
  #118
Tjolley's Avatar
Yes the engine is still running like a top.
Problems hmm if u consider not enough fuel or maxing the MAF table before 6k to be a problem. Lol
My ******* put the phenolic back and has a small leak nothing major. Just gona pull it off.
The car is in the garage apart awaiting some new fuel system parts and short ram 3.5" intake.
Old 01-31-2014, 09:10 AM
  #119
574
574's Avatar
How's the new intake and tuning going?
Old 01-31-2014, 09:16 AM
  #120
Tjolley's Avatar
Car is still sitting in the garage. Need to pull the phebolic off.
Old 01-31-2014, 11:59 AM
  #121
Ahh guess that dies it for me then, when my phenolic cones off its not going back on
Old 01-31-2014, 12:13 PM
  #122
ItalianJoe1's Avatar
You guys giving up on those spacers, send them to me
Old 01-31-2014, 02:42 PM
  #123
freakta's Avatar
How long before you can run it on a Dyno? How much more break in does it need?
Old 02-26-2014, 05:17 PM
  #124
V8THIS's Avatar
any updates? who knife edged your crank? can i have some contact info? id like to have my lnf crank knife edged/lightened/balanced
Old 03-02-2014, 09:09 PM
  #125
Tjolley's Avatar
Nothing crazy.
Just waiting on a new APP sensor from CED.
I knifed my crank myself.
Quick Reply: Tjolley's stroker LSJ
