Tranny help
Tranny help
I have a 2006 Cobalt SS w/o the LSD. I know that people go out and buy the G85 tranny b/c it has the LSD in it. What are the difference between my tranny and the G85. Because if it is just the LSD I can go out and buy LSD for my tranny. If anyone can give me the differences on both tranny that would help me out a lot.
my father and i have done a few lsd swaps for these cars.(hes been building trannys for over 40 years) getting fourth and fifth gear off can be a pain and getting the cases back together can be a bit tricky. good luck with the swap if you need help let me know were located in the cleveland area.
i was looking into the same thing. i talked to my mechanic and he said it would be more reliable to just get the G85 tranny and install it then try to pull everything out of your tranny to put LSD in it then put it back together.
hmm. i disagree if someone qualified does it then imo it would be better then finding a g35 from a junk yard or whoever. reason being if you buy off another person you dont know what kind of abuse its been through. if you swap out a new quaife you know you have a diff w 0 abuse also bearings are fresh and seals aswell.
for the actual amount, even with the cheap OBX LSD, that's $400, then you're looking at iirc someone said about $600 for the install IF and a big IF you can find a shop to install it.
I only paid $690 something shipped for a G85 trans, so why bother with installing one?
