tranny swap ?
ive always known the dificulties of the 6t75, i learned about them in an ATRA training seminar about a year ago. its really no different of a system than any of the new gm 6 speeds, it was about 3 years ago that i first learned about the new gm system with the tcm mounted on the valvebody. but hey, better than the new vw tranny, when you have to change a speed sensor you have to replace the tcm as they are mounted on one unit.
that would be the 6t40 in the malibu and saturn astra. its rated for 277ft/lb. the 6t70 (in v6 malibu, saturn aura) is rated for 280 and the 6t75 (Saturn Outlook, GMC Acadia, Buick Enclave) is rated for 380ft/lb. there is likley more applications, thats just what they were in during the first year (2008).
just to compare, the 4t45e is rated at 325ft/lb.
http://www.batesengineering.info/
you can put a pre computer controlled tranny in your car look at the link they sell adaptors to do so i believe gm racing dosent run computer transmissions they are full manul shifted autos
the cobalt drag cars run a race 4t65e hd. it has a host of mods to make it survive, including removing the 4th gear clutches and hub to turn it into a 3 speed. it was originally a fully electronic transmission (the 4t65e came out in 97) however what gm racing does is supply power to the solonoids and then use toggle switches to controll ground. basicly both on for 1st, one off for 2nd and both off for 3rd. the reason you dont do this on the street is becuase there is nothing to controll line pressure, so you have full line pressure shift all the time. this can damage the tranny and will be unbearable to drive.
ThoR294
10-04-2015 08:44 PM
