Turbo Suggestions
its got sludge?
yea seems like they may be the one im gonna get. i will probably not want to stay at 350 for long, lol. so this may be a good benchmark.
Last edited by fballman1987; 08-25-2008 at 03:34 PM. Reason: Automerged Doublepost
#36
http://www.rx7store.net/product_p/garrett%20gt2876r.htm
bump, anyone else have any suggestions or agree with anyone else?
Last edited by fballman1987; 08-25-2008 at 08:06 PM. Reason: Automerged Doublepost
#38
#42
yea i was really thinking about that one, but i think im gonna go with the 2871r or the 2876r. maybe if i want to get adventurous ill get the 3071r down the line.
#44
from a PM with Kennyspec he said the 2871 spools to 15lbs at around 3500rpms. the 3071 is a little larger so i would assume it would spool prolly around 3800-4000rpm, correct me if im wrong though.
#46
#47
the "30" series compressor wheel requires enough extra shaft inertia to slow spoll by 500-700RPM with the same 71mm turbine VS the "28" series wheel.
the difference gets larger and larger as your set up goes "wrong"
for example if your using a log manifold Vs a nice tubular unit and a non-flow directional wastegate (cause's lots-o-turbulance) VS one that is.
things like that.
also, dont forget that charge pipe routing and sizing plays a HUGE role in turbo "lag" 2.5in will spool quicker then 3in due to the lesser volume that the turbo has to fill. Also bends in the charge pipe has an effect as well. every 7deg of bend = 1 extra foot of the pipe the air "see's"
things like that.
#49
i think ive picked the turbo i want.
http://www.full-race.com/catalog/pro...roducts_id=258
where are you guys generally getting your turbos from? shops on your areas or online, where?
i need to start a list of everything i need. any help would be greatly appreciated.
