Turbo Swap
Turbo Swap
so i am using zzp to trubo swap in my lsj, i got everything only thing im left in the dark about is will my stck fuel pump hold up?? where do i tap the oil feed and return?? and who can i get a good tune from p or trifecta?? i need atleast the base map so it will start haha
I'm too JDM for you
you remove an oil galley plug from the rear of the block, screw the adapter in with some teflon paste and connect the line to the turbo. the oil return line goes from the turbo to the oil pan. you need to remove the oil pan, get it drilled and the get the fitting welded
ight thanks ill be starting it tomm, preciate the help, sounds fun, and i live like 5mins north of butler, ya there allot of honda and sti guys around here..
OK so im about to do my turbo swap and now this morning i get eng pwr reduced on my ss? wtf is that?? after letting it run for little then shutting it of for like 10 it started and was gone never had that??
ThoR294
10-04-2015 08:44 PM
