tvs 85 or meth
If you don't have a referenced system you'll need 1000cc injectors if your running e. If your on gas, you can get away with 60s depending on type of tune you have. Lean or rich. If you have a referenced system you can just use 80s with e. But you may be getting close to going static .
Not necessarily, you can go too big with the injectors and not be able to get the car to idle. On our old turbo e85 car, it had ford white tops in it, and the fuel pressure dropped way down in order to get the injector pulse above the minimum valve the haltech could output.
