TVS needed for 400whp? Nope.... ;)
Of course, but not everyone wants a turbo, I wanted a blower car for once, big rapping cams, violent powerband, etc.
It could have used a LSJ case so I didnt have the problem I have now, but I wanted to make use of this case that we had sitting around.
Its not a stock 2.4L bottomend.
Originally Posted by WSFrazier
How does the ZZP 4.45 trans differ from Powell's 4.45? I noticed you said an different case.
Originally Posted by ItalianJoe1
You're spinning the 2.4L bottom to 9500?
still would of been cheaper to do a turbo swap.
just giving you a hard time. congats
*ball tap*
that theory goes with bone stock LSJ, m62 & 93 octane pump gas.
everyone has known for months that a stock LSJ & m62 with E85 will get past that 300whp barrier with the proper tuning & fueling additions.
*ball tap*
#36
Whats the rpm @ 80mph? im doing the swap now and i drive on the freeway sometimes so i was just curious.
I will also need to know how to fix the speedo, i have hpt but dont know which numbers to change. lol
#41
Like how your intake is super short also lol. Did you delete the abs all the way and how did you mount your pcm to the car? I really want to get rid of that piece of crap plastic box its in.
#42
looking at the size of the pulley compared to the snout in the pics + 13psi of boost its running and high RPM id guess its a 2.8 maybe even 2.9???
In for a official answer though.
TurboTim, if you do start spinning 9500 or some where near what pulley will you go to then? or will you stick with the same one?
Great numbers!!! I wish ZZP Stroker Block was out when i sleeved my block. I think they came out to about the same price even lol
#44
I think to change needed for the 4.45 and speedo is the "err correction" or something like that. 1 thing says final ratio and the value is 1.00. next to that box it says err something or other with a value of 3.05. I would take a guess and say put 3.45 in for that value.
