TVS needed for 400whp? Nope.... ;)
Old 11-01-2010, 10:03 PM
  #51
Jrhdpaintball's Avatar
good work zzp.... need more info on that heat exchanger tho
Old 11-01-2010, 10:21 PM
  #52
RooTBeeR's Avatar
bitchin
Old 11-02-2010, 01:09 AM
  #53
Rent me! per hour
Area47's Avatar
ya had to beat me by 21whp. damnit and i sold the car. lol!
j/k
efficiency at work kids
Old 11-02-2010, 01:18 AM
  #54
RooTBeeR's Avatar
lol, you did still have more power per liter/ci than him tho
Old 11-02-2010, 01:26 AM
  #55
elecblue06's Avatar
how much trq you run? also i'm loving the only 13 psi lol win.. 2.4 built + built head is win
Old 11-02-2010, 07:29 AM
  #56
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by jrhdpaintball
good work zzp.... Need more info on that heat exchanger tho
x2 !!
Old 11-02-2010, 07:47 AM
  #57
Turbo Tim's Avatar
It requires removing the front bumper support, but the bumper support is aluminum and chincy anyway.
Originally Posted by laser_racer
Like how your intake is super short also lol. Did you delete the abs all the way and how did you mount your pcm to the car? I really want to get rid of that piece of crap plastic box its in.
Yep, removed the ABS and it is a 4" intake tube.
Originally Posted by troyss
What size pulley just like someone else mention??????
ATI OD balancer and a 2.7" pulley, When I hook up the speedo I will probably drop the pulley. Spinning to 9k+ wont be a good idea with my pulley setup. lol.
Old 11-02-2010, 08:44 AM
  #58
Ryan@zzp's Avatar
Originally Posted by hungryhip-ccp
Whats the rpm @ 80mph? im doing the swap now and i drive on the freeway sometimes so i was just curious.
I will also need to know how to fix the speedo, i have hpt but dont know which numbers to change. lol
It's just over 3100 rpm or so. My car has the same final and it is about 3050-3150. Off the top of my head.
Old 11-02-2010, 12:30 PM
  #59
troyss's Avatar
Originally Posted by bluecobalt99
nicely done
j/k
You made 380ish on an m62?
Old 11-02-2010, 12:42 PM
  #60
Administrator
Administrator
Staged07SS's Avatar
you made 380ish on an m62?
tvs.
Old 11-02-2010, 12:44 PM
  #61
hungryhip-ccp's Avatar
thats not bad at all! thanks.
Old 11-02-2010, 12:48 PM
  #62
troyss's Avatar
O I thought he was talking about a STOCK blower
Old 11-02-2010, 12:50 PM
  #63
Is this the one your running? I see it fits up to 8 groove belts with no modification.
Are you the one running a modified crank key way? Is that required to run this?
Mine is bent slightly from removing my engine and i need to replace, i might as well upgrade!
Old 11-02-2010, 01:49 PM
  #64
Turbo Tim's Avatar
Yes all of our rebuilt engines that we offer will have the modified crank keyway. I have destroyed 3 crank pulleys just by myself.
Old 11-02-2010, 01:52 PM
  #65
Turbo Tim's Avatar
He had a TVS, but my blower is stock, well besides grinding out the inlet to match the LS4 tb that is installed. The outlet is completely untouched though.
Old 11-02-2010, 02:05 PM
  #66
shroogis's Avatar
I had a crank pulley crack and destroy my front cover. Is that related to what you're talking about?
I'm still very impressed with this accomplishment. Great job guys at ZZP!
Old 11-02-2010, 02:55 PM
  #67
Rent me! per hour
Area47's Avatar
yulp!
Old 11-02-2010, 03:31 PM
  #68
100% METH's Avatar
Nice job Tim and Ryan@ZZP
Any way you could change your dyno graph to show rpms instead of speed?
Old 11-10-2010, 07:00 PM
  #69
ebristol's Avatar
That's a lot of engine options...
Cobalt & Ion ---> ZZ Performance
DarrenGC
12-24-2021 01:55 PM
hacadacalopolis
10-28-2015 06:09 PM
OrangeCoba
10-01-2015 10:00 PM
SSLOW06
10-01-2015 07:21 PM
Iceberg
09-29-2015 12:33 PM
Quick Reply: TVS needed for 400whp? Nope.... ;)
