TvS pulley
TvS pulley
Got a question , well a Noob question i about to order the TVS, now my questions is i understand it comes with a 80mm pulley already, now i have a bunch for my eaton m62, ranging from 2.5 to 2.8 pulleys. Can i use those on the Harrop or do i have to order different ones for harrop?
stick with the 80mm, under that you will run into heat issues
i run the 75mm, the heat is up there and you should run a meth kit plus more cooling mods
70mm you need a return style fuel system
use harrop pulleys or nate makes them now for thr harrop bolt pattern
Last edited by quadracer0387; 09-17-2008 at 07:34 PM. Reason: Automerged Doublepost
Well return style ill get after jan. with my tax return...
Now i have all cooling mods with ported intake mani and dual pass etc.. im looking into a killer chiller saw a post last night for stage 2 for $549
