TVS Set-up Suggestions??
Old 02-16-2012 | 07:48 PM
nizzle's Avatar
2.7 pulley, 1.75" primaries on header. Engine still making power at shut off point (7200 rpm). I could pull more power out of it if i upgraded my valve train so i could go higher on rpms
Old 02-16-2012 | 08:00 PM
jgarciarivera's Avatar
How much boost with that pulley? Considering your HP and TQ (and mods of course), in my opinion those are good numbers. An upgraded valvetrain is key to getting more power. Also, I'm getting a ported head, so that will add substantial gains.
Old 02-16-2012 | 08:54 PM
carstedt's Avatar
nizzle we nvr got to run again! lol..my cars shipping back to wisconsin here in a couple weeks before i head out to afghanistan
Old 02-17-2012 | 01:59 AM
InfraRedline's Avatar
Originally Posted by zrated89
oh hai. infra guess what just showed up
I saw in your thread! Lulz will be had on that pulley
Originally Posted by advise
only 05's have weak pumps i believe
infraredline is running 1000's on stock pump on e with no problems
Mine is an 05 Big injectors on the stock fuel system isnt exactly the "correct" way to do it, but it gets the job done for now. I may pick a a new pump and rewire soon.
Old 02-17-2012 | 04:24 AM
nizzle's Avatar
22psi
damn son! afghani huh? you coming back here or going somewhere else after?
Old 02-17-2012 | 11:42 AM
ebristol's Avatar
i ran the tvs with a 2.6 on e85,80's,and stock fuel system for awhile
Yeah. Then your engine blew.
https://www.cobaltss.net/forums/2-0l...y-gave-267214/
Don't post stupid **** like that in threads like this...
Originally Posted by cobalt5SS
Hey guys,
80#s
E85
TVS (Stock Pulley (80mm I believe))
Stock fuel system
ZZP dp (w/cat, 2.5" in, 3.0" out)
Honed GMPP manifold
Vibrant 3" exhaust
Option B dual pass
K&N intake
I don't care about what anyone says. Get some sort of Header/dp combo. Even a Bad-mab at the minimum.
I maxed out the stock fuel system with a TVS, 2.9" around 6300rpms. My injectors went static and the system leaned out. The TVS makes peak HP around 7200rpms so you need to rev it past that.
If I were you, I would not run anything smaller then the stock TVS pulley until you upgrade your fuel system.
With a good tune, you should make between 315-320whp with the stock TVS pulley and E85.
Old 02-17-2012 | 11:56 AM
advise's Avatar
interesting so if i got rid of my balancing shafts and got new valve springs the tvs would make power to 8k or would it drop of with stock cams
Old 02-17-2012 | 12:07 PM
ebristol's Avatar
It would still drop off way before 8k.
With the stock head, the TVS out flows the LSJ. So the TVS is moving way more air then the engine can handle. And the stock cams do not help either.
Here is some dyno runs I did with my TVS and M62.
Red and Green are TVS.
Look at how the boost spikes at the end of the run just before 7 grand.
To rev to 8K with the TVS, you would need balanced shafts and valve springs for sure. Then either cams and a ported head.
Personally, I would go with the ported head first. That should move your powerband a couple hundred RPMS and provide good gains across the board.
Cams are going to move your powerband higher up in the RPMs but might cause you to loose HP/TQ on the low end.
Old 02-17-2012 | 03:16 PM
cobalt5SS's Avatar
I've got a 3.0 pulley that I will make my limit as far as size goes. Any smaller I gonna buy the boost by reference from ZZP.
Is ZZP bosst by reference better than OTTP return style.?
Is one more necessary than the other?
Old 02-17-2012 | 03:20 PM
cobalt5SS's Avatar
As far as running a 2.6 on a TVS with the stock fuel style.... I feel that was just asking for it and who ever tuned it should of had some indicators of a potential BOOM.
Old 02-17-2012 | 07:35 PM
  #36
ebristol's Avatar
I don't know if I would say one is better then the other. ZZP used to say that Return Style was useless but now their kit has the Return option.
I just bought an OTTP Return style from this guy.
https://www.cobaltss.net/forums/part...s-more-271150/
I got a steal! I don't need the extra fuel now but probably will in the future.
Old 02-17-2012 | 08:56 PM
  #37
1fastSSBalt's Avatar
Not to thread jack but could just porting the exhaust side suffice for better flow or is it completely worth a full port and polish with valves springs balance shafts because the set up I have is some what similar except im going to try the zzp lth with catless dp to 2.5 inch catback. =D
Old 02-18-2012 | 01:29 AM
  #38
mrbelvedere's Avatar
you will need cams to make power to 8k
Old 02-18-2012 | 02:57 AM
  #39
cobalt5SS's Avatar
I need a header bad. That GMPP honed mani is horrible in terms of what I really need for my set up. Bad-Mab seems like a cheap option. I just got a 3'' vibrant exhaust which I cannot wait to hear.
I'm really concerned about my piston rings with the TVS setup..
Old 02-18-2012 | 11:05 AM
  #40
zrated89's Avatar
as long as you have the correct fueling, and a nice flowing exhaust, with some cooling mods to maintain the iat2's dont be worried about piston rings. WITH A GOOD TUNE THAT IS. im about to put my 2.6 on right now. im still on 93 with meth and 80's
Old 02-18-2012 | 11:27 AM
  #41
oh **** grow a pair the second you rake the car away from stock reliability goes out the window tune tune tune
yup
Old 02-18-2012 | 11:28 AM
  #42
zrated89's Avatar
and not leave it at a dealer with little meth in the tank. sorry man had to you know im ******* with ya
Old 02-18-2012 | 11:34 AM
  #43
a 1/2 gallon was left
its all good mcpimp its back together and rollen thats all that matters lol
Old 02-18-2012 | 02:29 PM
  #44
On E85 and stock pulley get a good tune and fuggitaboutit! Youll be fine
Old 02-18-2012 | 04:03 PM
  #45
carstedt's Avatar
[QUOTE=ebristol;6345305]Yeah. Then your engine blew.
i can post that cuz my engine blew to my own stupidity...was the fuel system pushed hard? yes...but i ran it hard with that set up for months and nvr changed the plugs or bothered to even look at them even after switching to e85 or after tuning..it was my own fault it blew up not the tune or the fuel system being pushed
Old 02-18-2012 | 07:59 PM
  #46
cobalt5SS's Avatar
Shake n bake
Old 02-19-2012 | 03:58 AM
  #47
cobalt5SS's Avatar
Suspension wise, what do I need? So that my engine doesn't beat around like a jack hammer.
I have the stock mounts, all over. I've even replaced two of them already. That was fun.
Old 02-19-2012 | 12:13 PM
  #48
zrated89's Avatar
TC trans mounts and be done.
turbochargedss2012
09-20-2023 01:17 PM
Sl0wbaltSS
11-22-2018 12:11 AM
TedSS
26
10-10-2015 05:30 PM
SSLOW06
10-01-2015 08:21 PM
yellow dragon
09-28-2015 10:49 PM
