Twin-Charge anyone?
Old 08-01-2008, 01:32 PM
  #101
ss sleeper's Avatar
Originally Posted by Zooomer
does the blow off valve go nexto the intercooler?
Old 08-02-2008, 10:55 AM
  #102
Brian MP5T's Avatar
^^ I guess this one does...
Old 08-03-2008, 06:46 PM
  #103
bluechevycobaltss's Avatar
did they say how long it would take to instal
Old 08-03-2008, 06:55 PM
  #104
WickedSS2005's Avatar
Talked to Chris today, he says mid to late this week
Old 08-03-2008, 06:56 PM
  #105
04redline0124's Avatar
his name is chris to? lol
Old 08-03-2008, 07:00 PM
  #106
Jeremy360's Avatar
Grats, can't wait to see it finished, post those vids/#'s
Old 08-03-2008, 07:02 PM
  #107
I know 6 or so Chris's. People need to get creative damnit
Old 08-03-2008, 07:03 PM
  #108
hungryhip-ccp's Avatar
my names chris
Old 08-03-2008, 07:07 PM
  #109
Originally Posted by hungryhip-ccp
my names chris
lmao damn man thats me you, altiery, and now this guy in this thread lol
Old 08-03-2008, 07:10 PM
  #110
refosterIV's Avatar
<click> and good luck looking forward to results.
Old 08-03-2008, 07:24 PM
  #111
musta been populare in the 70's 80's
Old 08-03-2008, 08:24 PM
  #112
jgarciarivera's Avatar
keeping an eye in this thread
Old 08-03-2008, 08:34 PM
  #113
PimpLay2's Avatar
hope u have no problems with it man
Old 08-03-2008, 09:58 PM
  #114
BlueSS-supercharged's Avatar
cant wait to see it
Old 08-04-2008, 12:45 PM
  #115
Supporting Vendor
Zooomer's Avatar
Updates:
Everything including the oversized intercooler bolted in with no cutting or modification. Everything uses existing mounting holes and bolts so there was no cutting, even with the massive front mount. The parts all look factory and I even had to ask if the turbo kit was fully installed looking at the car on the dyno. It was so I am very impressed with the fabbing and color choices the guys made for all the parts, hoses and boots.
The car is using all turbonetics boots, blow off, wastegate, etc. No expense was spared. We are experimenting on the dyno with a solid intake duct vs. flexible currently.
The car is responding better than our Cobalt did but part of it may be due to using production parts and oversized everything.
The car is currently making 301WHP at 6k rpm with 18psi and 9.8:1 AF ratio. You can't get any more conservative than that so we expect 350WHP on less than 20PSI but we will ultimately be leaving the HP number up to the customer. The build looks to be ready for 500WHP but I"m not sure the clutch, axles, etc are up for it. Nor do I know if the customer wants to take the risk with a stock engine. Right now, we're just tuning it all in and getting the vac lines right and the supercharger/turbo switch setup, etc. We will rev it up higher, lean it out, and up the boost (if the customer wants us to) and report back.
The bad news is that the tune is off from our car. With everything the same, the car is 2 pts lower AF ratio than ours was. This could be due to 07/06 difference, MAF differences, injector differences, etc. We're not sure but the kit may require a tuner for final fueling to be dialed in (on shipped kits). This car has a return style fuel systm now and 60# injectors. I can't tell you guys how pleased I am with how good this install turned out. I'll post back once we discuss with the owner final goals for power and such.
Old 08-04-2008, 12:49 PM
  #116
lewisb13's Avatar
Location: Home: Utica, MI Current Location: Mobile, Alabama
55psi FTW!
Old 08-04-2008, 12:57 PM
  #117
Rent me! per hour
Area47's Avatar
no two cars are ever the same.
Old 08-04-2008, 12:58 PM
  #118
sweet keep up the good work guys
Old 08-04-2008, 01:08 PM
  #119
Took the words outta my mouth.
I challenege your twincharge kit to my TVS! Chris and I have already talked about it. It's gonna be more epic than stg2 vs GTO!!!
Old 08-04-2008, 01:28 PM
  #120
Razor564's Avatar
For plates 502slow
Old 08-04-2008, 09:39 PM
  #121
07blackSC's Avatar
Originally Posted by Razor564
For plates 502slow
i like this plate too. but once the police figure it out it....yeah instant ticket
I really want to see how TVS and twincharge compare so I guess we will be going down some roads by your place. and as for being more epic and STG2 vs GTO:
Old 08-04-2008, 11:26 PM
  #122
06black's Avatar
you take your twin charge car, the other guy get his TVS car, and I'll bring my turbo car.
i likes the sounds of this.
Old 08-04-2008, 11:33 PM
  #123
Tazmanian_Dvl's Avatar
nice
Old 08-04-2008, 11:59 PM
  #124
MrSlickSter06SS's Avatar
I got my vote on Wicked "" don't let me down budy ;P
Old 08-05-2008, 12:26 AM
  #125
Matt M's Avatar
We started to get this setup dialed in this afternoon. At 22.5 psi, 11.7:1 AFR, conservative timing, it peaked at 384 whp at 6800 RPM. Adding a couple more psi took it past 400 whp at only 6300 RPM, but the pull was cut short due to a miss. We plan to gap the plugs a little tighter and make a clean pull at 400 whp.
06black, what turbo are you running?
Quick Reply: Twin-Charge anyone?
