victory_red_SS goes RWD
#1779
#1780
LSX RWD S/C conversion
TURBO Pictures
I thought you guys would like to see that the GT-45 isn't as big as you think.
You will also notice that the turbo sits above the hood line. To accomodate this it has beemed necessary to raise the hood, Ram Air style. The plan will be to have two front openings, one to feed the turbos and the other to cool the engine bay. There will also be heat extractors on the back of the hood. The raised section will follow our stock hood lines.
I hope you win
Sounds messy
Sounds messy
#1784
guess what this car is guys.....
that thing is coming together nicely
#1787
#1789
#1797
And to Victory - when it's done, will you take it to a closed course to do a top speed run? You know, just for ***** and giggles?
#1798
1 Post
It is hard to imagine that the motor has enough exhaust to run that turbo and the little one. man it is to bad you could not build it to look like the stocker other than the tires cause that would be just a shocker to most. a very different sleeper LOL. but hey the monter within can not be contained in stock sheet metal then so be it. YOu still have my support.... I just hope you put a third seat in the rear for some awfully crazy nut to allow his nuts to dangle with your drive shaft between his legs......... taken out of context that just does not sound right
K I will shut up now!
