Warning!!! Dont do this..
We have finally started tuning my car after the build and got to drive it some starting to break in the new rings and what not. What I am referring to as in the title, in the build i added neutral balance shafts and I have solid motor mounts. Those two are not a good mix unless you love EXCESSIVE vibration, I mean it is insane. Just a warning for future builds. I am now about to switch to the new rotated mounts as they cause less vibration.
wont always happen. i built a friends motor with levelzero balance shaft delete kit and urethane mounts, its smooth as butter. i however do a step many deem unessesary, i send the rotating assembly out for balancing. i have a very pickey engine balancer, most will get each hole (rod, piston, rings, bearings, pin) to within 2 grams, my balancer gets each peice down to 0.2 grams and balances the rods end to end.
balancing is a very cheap step of building a performance engine, i dont know why so many people dont bother, there are deffinite payoffs.
jcalvin1126
09-11-2015 10:24 AM
