Water/Meth Question
Old 04-05-2007 | 10:34 PM
CobaltSS313's Avatar
Question Water/Meth Question
If you inject water/meth before the TB do you have to do it through the intake, as in drilling a hole in the intake?? Also is there a difference if it is before or after the TB because its still before the supercharger.
Old 04-06-2007 | 07:14 AM
blueta's Avatar
The difference between before tb and after is that after the tb you'll have vaccuum. Meaning you'll NEED a check valve or solenoid to keep your mixture from being sucked in while just cruising. I however recommend putting in a cv or solenoid even if it's before the tb. It's just nice cheap insurance that your lines will always be filled with alcohol. HTH
Old 04-06-2007 | 07:22 AM
DTM2188's Avatar
^^^x2
Old 04-06-2007 | 06:18 PM
so on CA, other than the snow performance kit, what else will i need to buy, i plan on getting the TB spacer so i need to buy the solenoid but what is the tapping spacer for the methanol jet, do i need to buy that too? thanks
brandon04
10-21-2015 07:04 AM
nathan112i
09-30-2015 07:12 PM
Iceberg
09-29-2015 12:33 PM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
Quick Reply: Water/Meth Question
