Water pump 2.0 LSJ
Old 01-21-2010 | 12:53 PM
NightriderCobaltSS's Avatar
Water pump 2.0 LSJ
The dealer told me i need a new water pump and it was going to cost me 750...i went on the web found and ordered this one for 70 bucks
then i was browsing around and i found this
since i dont know what is that on the second one and if i have a leak in my water pump did i really need the second one..?
Any help you could provide would be great!
Last edited by NightriderCobaltSS; 01-21-2010 at 12:53 PM. Reason: Automerged Doublepost
Old 01-21-2010 | 01:04 PM
JapEatr's Avatar
South Central *********
it shows the chain gear on the second one.
i would suggest getting one of these as well
also taking the exhaust manifold off is helpfull to get the coolant pipe out of the way
Old 01-21-2010 | 01:05 PM
i bought the first one....can i still use the first one or do i need to buy the second one with the chain gear..?
Old 01-21-2010 | 01:09 PM
JapEatr's Avatar
you can reuse the stock gear. that is what the tool is for.
it holds the gear and chain in place, then you remove the WP off the back side and line the new pump up with the bolt holes in the gear being held with the tool.
google Ecotec Water Pump Tool... the one shown is a Lisle brand, which is what i use
this will save you lots of time and avoid a fight with the balance shaft timing chain
Old 01-21-2010 | 01:11 PM
ok ...i havent opened it up is there a way i cant tell if they stock gear is messed up too or is that a open it and find out ?
Old 01-21-2010 | 01:34 PM
JapEatr's Avatar
unless you jumped a tooth it wont be messed up.
Just take you time and goes easy when working on getting the WP bolts out, and everything will be good, also make sure you get a WP gasket
Old 01-21-2010 | 03:08 PM
how can u tell if u "jumped a tooth " maybe a stupid question..but id rather ask so i know ?
Old 01-21-2010 | 03:25 PM
JapEatr's Avatar
doubt it did, if the pump is just leaking there is nothing to worry about.
another suggestion is to get the oring that goes on the coolant pipe as well, that way you are prepared,
Old 01-21-2010 | 04:16 PM
mrbelvedere's Avatar
you dont need new gaskets they are all o-rings and the pump is a bitch to change
Old 01-22-2010 | 03:23 PM
thats why im not doing it...just trying ro find out all the info i need...
Old 01-23-2010 | 10:55 PM
Does the the timing chain and Themostat need to be changed out when you change the water pump? Someone told me it did...trying to bounce it off the fourms here since the information here is usallt good info
Old 01-24-2010 | 11:13 PM
no it dosent
Old 01-24-2010 | 11:35 PM
shadowfaxss's Avatar
The timing chain does not.....however, if you never changed your thermostat and are changing the water pump it is a good best practice to change the thermostat. This way you only open the system once and only need to purchase coolant once.
Supercharged06SS
12-11-2022 05:47 PM
05-28-2022 04:47 AM
DarrenGC
12-24-2021 02:55 PM
06MetallicBalt
08-17-2021 04:40 PM
09-28-2015 01:51 PM
Quick Reply: Water pump 2.0 LSJ
