Weapon R Header IS MUST HAVE!!!
#153
Any dyno numbers on this yet? Victory, is there definetly is a noticable difference after installation???
I'm considering buying this header, before upgrading my injectors and going HPtuners.
I'm already hovering around 13.0 A/F, it actually dips down to 12.0 from 6k to redline. My question is, do you think it will be safe installing this header? I assume the car would run a little leaner with the free flowing header, since I'm already around 13, I DON'T want to go any higher!
Any insight would be much appreciated!
#154
Thanks Mercury, i try. :-p. i deff recommend this header, especially with the way ur going turboeco. if u get that hp tuners ull be able to adjust ur a/f ratios so im told. if u want the tq gains then this is the way to go.
#158
#159
question,
in that video, the clutch seemed to grab instantly and you could go WOT with no wheel hop and hook up, my crappy stock clutch would slip from the 1st to 2nd.
Do you have an aftermarket clutch, Ingalls?, Motor Mounts?...?
#161
Nice looking long tube header
Is the 1st o2 sensor in one of the tubes and not in the collector? From what I could tell from the pictures it seems that it's sampling from only one cylinder correct?
Any chance this header will be produced with a 02 sensor sensor bung in the collector instead of one of the four primary tubes. I could see problems with air/fuel mixtures as the ECM will be sampling from just one cylinder to get a reading. I would probably put two sensor bungs in the collector...one for stock o2 narrowband and the other for a wideband. I think that's the only thing along with the price that's keeping me from purchasing this.
Nice to see someone is finally making a decent header for our cars.
#163
Originally Posted by CobaltSS422
Victory..... Any reason why you went with the Corsa Touring Exhaust and not Sport?
because he knows i have the sport, and when were bored. i.e im deaf and hes not, then we will switch untill hes deaf and my hearing comes back.
#164
was the header ever dyno'd before and after ?
just dynoing after isnt gonna say a whole lot , since the car is heavily modded already
ive seen headers have problems with being welded on both sides , to much heat in such a small area usually changes the temper of the metal
also another thing i noticed that the header was not set up right , the header isnt set up to match the firing order
it looks pretty nice , is that header the 1 you want to try on the cavalier/sunfire ??
#166
#167
#168
#169
Originally Posted by silverSS
second one, you get it replaced under warranty for free or what?
#170
Originally Posted by VictoryRed06
theres an o2 sensor before the collector yes. i am unaware wether its sampling for one cylinder, thats something to ask ray at weapon r. im sure design of the header will change as time goes along, but i dont think theres any plans for them to do 2 o2 sensors like what your asking.
thanks
#171
Originally Posted by DanJHartman
that video is badass man that sounds insane.
i think this should work for people who cant see it
http://vids.myspace.com/index.cfm?fu...=711122353&n=2
#172
Ok well if you all liked that video here is a simple teaser, Victoryred06 is still here and heres the clip of the header on the dyno.
ENJOY!
http://www.youtube.com/watch?v=81Yyk8KeT0k
ENJOY!
#173
Now here is the one from the rear with his exhaust sound.
http://www.youtube.com/watch?v=T_RHl3LY538
#174
