Weird noise from supercharger?
#76
^^ Good to hear man! Glad you got your ride fixed up. I'm still debating on what to do with my situation...
Anybody else think the coupler could still be bad and make noise even if there is no noticable play in the pulley? (take off the belt and wiggles pulley back and forth) Ideas..?
#77
Haha no no man...
My pulley DOES NOT wobble...
I was saying to test for a bad coupler, you take off the belt, and twist the pulley back and forth and check for a wobble. If there is play and wobble then the coupler holes are worn and it needs replaced...
I will likely replace my coupler and oil when I have it all apart painting it...
#78
Haha no no man...
#79
Haha yea... That would be a scary situation... But no I just have the clicking marbles sound coming from the blower. It started after I ported the outlet and threw a 2.7" on it. Soo the coupler is likely going, or the bearings in the inlet side...
#80
i would have to guess coupler, mine did the same thing with the 2.7, but fukkit check it all when u got it apart.
#81
Yea, I'll def check all the internals. I just don't know of any way to check the bearings though. And supposedly they are a bitch to replace since they are press fit into a blind hole, so they are hard to remove...
#82
#84
but if u do have them do it u should post up results and pics. could turn out to be a nice little how-to.
#85
holy ****, ur pulley wobbles??? i hope u dont snap some of the bolts holding ur pulley on form all the slappin around it's doin. u need to get that fixed asap and ur stock coupler is gona make noise, everyones does! if it bothers u that much then get one of the aftermarket ones mentioned before in the thread. i think theres a how-to on replacing this.
#86
ur telling me that a ZZP 2.7 inch pulley is pressed on... really??? i'm afraid i'm failing to see where on the ZZP website u see press on 2.7 pulleys for the M62 SC??? i think your thinking of the HUB in which the PULLEY is bolted to that...
#88
#90
Alright fellas, relax... No harm, no foul... Yes Taz, I actually have prolly one of the biggest bolt on SS/SC in the PGH area, besides the big dogs with cams, pistons, blower & turbo swaps, etc... I thought you knew that from chatting in the PGH thread.
And Mnatvyc1223 does still have a SS/SC, he stated it earlier in the thread.
But anyways, I just bought a ZZP Coupler and Oil, soo I'll see if that fixes the problem...
#95
I really cruise on the twisties...I get nervous cause you never know what's around the bend ya know. However the straight aways I get goin pretty good. My fastest is about 165. I ran outta room...
#96
Nice good stuff, I used to ride my bike down the parkway when I was going to Duquesne from Monroeville, and there have been quite a few times I've done about that because people have tried to "race me" in their POS car... Game over... </threadjack>
DANRICKARD
10-01-2015 12:08 AM
