Weird problem when starting car..
Okay, so, sometimes, the car will start as soon as you turn the key.. The normal 1-2 cranks, and it fires up like a champ.. Now, randomly, every 15 starts (or so), the car will crank 4 times before it starts. What would cause this inconsistency? It is completely noticeable, and horribly irritating.
A check list for you.
1.fuel in tank
2.battery terminal connections loose or corroded
3.worn, faulty or incorrectly spark plugs
4.broken, loose or disconnected wires at the ignition coil(s) or faulty coil(s)
5.fuel injector(s), fuel pump, fuel filter, pressure regulator
1.fuel in tank
Or the number of times you hear the crankshaft rotate?
1.fuel in tank
1.fuel in tank
2. Will check tomorrow morning.
3. Brand new plugs, (And fuel filter), were installed by myself when I first noticed the problem. Didn't fix anything.
4. Will check tomorrow morning.
5. New fuel filter was installed like I said above.
Maybe that information well help narrow it.
Times you hear the crank rotate. I'll turn the key once, and sometimes it'll rotate 2 times, like it should.. And, other times, it will crank like 5 times.
Sometimes cars just take longer to start, could be the weather.
Personaly I think your chaseing ghosts, and looking for a problem
where there isnt one.
roth
09-26-2015 12:16 PM
