Well, I finally blew up... Need advice
Old 08-07-2010, 06:00 PM
  #226
rico's Avatar
^ seen that. sucks
Old 08-12-2010, 09:03 AM
  #227
VeNoM0713's Avatar
update: my car is done! but now im getting a cel thats causing me to run in limp mode.. code is P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage -PCM
does anyone know whatcsensor 1 is? because there are two sensors.. i would think its the throttle body and the sensor in the gas pedal..
Old 08-12-2010, 09:05 AM
  #228
rico's Avatar
unplug and plug them back on , disconnect battery and plug it back in in 10 mins? try that already?
Old 08-12-2010, 09:52 AM
  #229
VeNoM0713's Avatar
yeah.. nothins workin.. i even tried deleting the code from hptuners lol.. the cel is gone but im still in limp mode lol
Old 08-12-2010, 09:56 AM
  #230
rico's Avatar
check ur maf?
Old 08-12-2010, 10:56 AM
  #231
Jazer's Avatar
Glad to hear you have her running Chris!!
As far as the code, from what I've gathered there should be two sensors in the accelerator petal assembly, they read voltage opposite eachother when the pedal is pushed down. One reads from high to low (sensor 2) and the other reads from low to high (sensor 1). It would appear that in your case sensor 1 dropped below the 'acceptable' voltage level, thus throwing the DTC.
Here are the codes avaliable for that system:
P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit -PCM
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage -PCM
P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit -PCM
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage -PCM
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage -PCM
Could you have interfered with those sensors at all? I would assume there would have to be a break in the circuit or the sensor is just bad. Unless they became disconnected at some point and weren't plugged back or or not plugged back in the correct spot.
Im not to familiar with anything further though.
Disclaimer, I learned this in a TB discussion but Cobalts were included in the list, I would assume the same accelerator pedal assembly was used between the different GM & Chevy models of the same year range). Hope the info helps.
Old 08-12-2010, 11:34 AM
  #232
ItalianJoe1's Avatar
Low voltage is just that, a wiring issue. You could try swapping in another gas pedal or PCM, or check the wiring between the two.
Old 08-12-2010, 11:46 AM
  #233
ralliartist's Avatar
sounds like you just need to get it out of limp mode now.
usually its p0068. set that to enable at 8000 rpm (disabled). It's on the main eng diagnostic page. That is your map/maf/throttle position correlation code.
Old 08-12-2010, 12:47 PM
  #234
VeNoM0713's Avatar
lol, i just loaded up my tune and thats already set to 8000.. i wonder if me extending my WOT box wires has anything to do with this.. but i soldered and heat shrinked the wiring..
Old 08-12-2010, 01:00 PM
  #235
boostedsport's Avatar
Originally Posted by ebristol
My boy Phil is still get fucked in the ass by Bates...
http://www.ionforums.com/forums/perf...ck-out-11.html
i'm going to get edelbrock to build my **** i cant believe that thread
Old 08-12-2010, 01:09 PM
  #236
insylem's Avatar
How about the LSJ Power Build Book
Old 08-12-2010, 02:02 PM
  #237
ebristol's Avatar
I know. I feel so bad for Phil. He spent a lot of money to get the best people possible to build his engine. Bates block and Maven building it.
But if the block is jacked it does not mean anything...
Old 08-12-2010, 02:04 PM
  #238
And to think all i heard were good things from Bates it would pay to ship your car to ZZP and have them do all the work. Next build my car is going to OTTP and i'm sleeping on the couch lol atleast JBP wouldn't mess up that badd
Old 08-12-2010, 02:05 PM
  #239
Mike08ss/tc's Avatar
Originally Posted by glen229
thats good, better then some members "self" builds on here lol....
i hear yah, just spent like $3,500 on parts plus a new motor to teardown myself
i wish i had your money. contribute to my toy fund.
Old 08-12-2010, 02:06 PM
  #240
rico's Avatar
im getting a gen II block to not worry about sleeves and having the local shop do the rest lol. bates so far lost my bussines with them . we will see
Old 08-12-2010, 02:07 PM
  #241
Jrhdpaintball's Avatar
certain pcms have a bulletin on them for throwing a 2138 code i believe. you have to replaced the pcm.
i kept throwing a 2138 code, along with 2122 and 2135i had to replace the pcm. while changing the pcm i saw that a wire going into the harness was just slightly pulled away from the inside of the connecter. so im not sure which one accually fixed it, but it got fixed. just pulled the lock out of the connecter and pushd the wire in until it clicked and locked it.
before this all happened. i did my intake. so is possible that the wire could of came out while i was unpluging the connector.
just something to look for. it was a pain in the ass for me, for the longest time. limp mode suckksss
Old 08-12-2010, 02:17 PM
  #242
agreed along with the whole ecotec comm
Old 09-15-2010, 09:20 AM
  #243
blackbirdracing's Avatar
Bates is geographically located near LA sleeve...
I wonder whos sleeves he is using...
Sorry for the dead thread bump.
Old 09-15-2010, 12:21 PM
  #244
VeNoM0713's Avatar
well, im not going to blame ray YET... ill be tearing down the motor AGAIN this weekend.. but unless my rich tune destroyed the rings causing ridiculous blowby, i will be calling him because if its not the rings, its the block. if its somehow the pistons, ott will be getting a call lol.. everything exhaust wise has to come out of the car because everything is COVERED in oil so everything needs to be degreased/cleaned.. i hope to god this is the last time im going to be tearing this down.
Old 09-15-2010, 01:53 PM
  #245
All this hate on bates...
I assembled a sleeved LNF block I got from Darton, has been perfect from day one. Every case is different.
Old 09-24-2010, 11:24 AM
  #246
Mr.N00bLaR's Avatar
So....?
Old 09-24-2010, 12:45 PM
  #247
VeNoM0713's Avatar
Originally Posted by Mr.N00bLaR
So....?
well the block is at O & L machine right now by my house... apparently ray bates fucked up.. gapped the rings wayyy too tight. but thats what the machinist said.. im getting the rings changed out, rehone and replacing the rod bearings.. but if this fixes it i know ray messed up. too bad he wont accept responsibility. i just hope this fixes the problem and ill be happy. ill take some pics of the rings when i get the block back
Old 09-24-2010, 02:40 PM
  #248
ebristol's Avatar
I hope this works out for you.
Old 09-24-2010, 09:15 PM
  #249
selfinfliction's Avatar
damn hope it works out.
Old 09-24-2010, 09:22 PM
  #250
donkeyballs's Avatar
Lol i was gonna talk to you about this guy doing my motor scratch that ! good luck to you on that hope everything works out.. oh and you might need a lil more to keep up next year..
Quick Reply: Well, I finally blew up... Need advice
