Well, I finally blew up... Need advice
Old 06-02-2010, 12:29 AM
Zach06CobaltSC's Avatar
I really hope that isn't the case after my motor is done being built. I don't want to start a hard pull and then have to cross my fingers as I shift and hope it doesn't go BOOM lol.
Old 06-02-2010, 12:30 AM
blackbolt89's Avatar
in for curiosity.
good luck with the build though.
Old 06-02-2010, 12:02 PM
Paulysplitx's Avatar
Its sucks to hear this thing blew up. It should be interesting to see what happened once the motor comes out.
Old 06-02-2010, 01:04 PM
stanced_balt's Avatar
new block, sleeve it, head is prob fine. dude youre not making more than 350whp reliably without steel sleeves.
Old 06-02-2010, 02:03 PM
SS/SCking's Avatar
welcome to my world buddy...
Old 06-02-2010, 02:24 PM
ralliartist's Avatar
I live in this world too....
Old 06-02-2010, 02:30 PM
ralliartist - you never call me any more *sniffle sniffle* *tear tear*. I will soon live in this world, but hopefully not for too long.
Old 06-02-2010, 02:32 PM
Witt's Avatar
Aftermarket sleeves if you can afford/aquire them, I have no idea who manufactures anything off the shelf anymore, been a while since I owned a Cobalt. When you have the sleeves installed, I'm sure this will be a given but just in case, make sure they are honed with a torque plate, call around and see if any local machine shops have an ecotec torque plate, not many do. Whoever's pistons you end up installing, make sure you use their recommended clearances to a tee. Also shoot for the ring manufacturer's recommended rings and gaps. I've used OEM bearings on the rods and mains to GM's specs with no issues, be sure to check those especially if you end up line honing the mains.
Old 06-02-2010, 02:37 PM
I'll be honest man. I lost your number. It was in my stateside cell phone that I no longer have. PM me your number and I'll give ya a holler occasionally.
Old 06-02-2010, 02:39 PM
not hard to make a torque plate if you own a machine shop. but yes, any open deck aluminum block requires a torque plate. MAKE SURE THEY USE ONE
Old 06-02-2010, 02:44 PM
  #36
Witt's Avatar
You would be surprised in how many either won't or say they will and don't.
Old 06-02-2010, 02:45 PM
  #37
haha that's why i'm stressing it a lot. it's ridiculous what these places get away with. wish i had my own machines!
Old 06-02-2010, 02:46 PM
  #38
Witt's Avatar
There are also vendors out there (not sure about this forum) that will assemble built short blocks and not follow basic procedures as well. Reputation is the first thing I look at when shopping around for one.
  #39
ewwww, I would be PISSED!!!!!
Old 06-02-2010, 02:51 PM
  #40
Mm hmm I see how it is guy, mmk. Have you made any progress on the extremely ported head?
Old 06-02-2010, 03:03 PM
  #41
Witt's Avatar
Take for instance a company like Hinson where my friend Greg called them out for doing just such a thing.
http://www.ls1gto.com/forums/showthr...97#post6828597
Old 06-02-2010, 03:13 PM
  #42
all kinds of progress.
I see.
Old 06-02-2010, 03:42 PM
  #43
VeNoM0713's Avatar
thanks for the advice.. ugh, this should be fun.
Old 06-02-2010, 04:22 PM
  #44
SS/SCking's Avatar
well if u need a new block ive got one...
Old 06-02-2010, 04:26 PM
  #45
mongorat427's Avatar
Ebay Item 140411286826 New hi-perf piston/rod/ring set for 2.0 Ecotec New high-performance Diamond forged pistons, with hi-po rings on shot-peened LSJ rods. This setup was removed from a built engine that never made it to the test cell. Look at the piston domes and teflon skirts: never fired - still has the assembly grease visible. Pistons are standard bore for 2.0 litre - will produce 9.5-1 compression ratio. All new rings, pins and retainers. Rods are OEM LSJ, but they have been shot-peened and fitted with trick A1 3/8" rod bolts. This setup could get a street or Sportsman to 300-400 horsepower. If you are not 100% satisfied with these beauties upon receipt, I will refund and pay return shipping. Match it up with factory cranks and blocks...on sale elsewhere on eBay from PartsOutWest. 6 HOURS TO GO on this auction
Old 06-02-2010, 05:18 PM
  #46
VeNoM0713's Avatar
ill keep you posted dan, were going to tear it down later
Old 06-02-2010, 05:57 PM
  #47
Laser Target's Avatar
Man that sucks. Good luck with the rebuilt interested to see what you do and how much power it will make when its done.
Old 06-03-2010, 05:26 AM
  #48
show the pics of the sleeves!!!!!!
Old 06-03-2010, 05:33 AM
  #49
hungryhip-ccp's Avatar
go with Ray Bates!
http://www.batesengineering.info/contact.htm
when i cracked a sleeve the coolant was gone in a few seconds i knew right then what happened. i hoped it was the hg but i just changed mine too 3days before also so i was like..... its a sleeve. other crazy thing is i was at the same mi as you.... weird all the turbo lsj go at about 30k mi.
the sleeves just cant hang for very long. mine went from 12k-30k
Old 06-03-2010, 09:18 AM
  #50
VeNoM0713's Avatar
will do ralli. i believe were goin to start the tear down later today. but yeah, i think a sleeve/sleeves is/are toast lol.. and thanks for the advice chris.
Quick Reply: Well, I finally blew up... Need advice
