Well, I finally blew up... Need advice
Old 06-17-2010, 04:51 PM
  #151
Stiner's Avatar
Originally Posted by ralliartist
I ran up that high with just valve springs. I'm sure you will be good with all that extra security.
But really, there isn't a need to shift that high 'cept for the 1-2 shift.
Turbo lsj car you would want to do it for the first two gears and then stretch it out in third if you are at the track as well.
1st so it hops into the meat into 2nd and 2nd gear all the way to 7700 so you don't bounce of the rev limiter before your tires start hooking again.
Old 06-17-2010, 04:52 PM
  #152
ralliartist's Avatar
Originally Posted by VeNoM0713
what about for the track though? cross the line in 3rd gear i hope lol. my trans hates me.. i get random mis shifts all the time at the track. i think my car in general just hates me.
hmm.. how much psi did you push the 20g up to? i know hahn says their supposedly good to 30 but im sure theyre full of ****.
good call, I didn't think about keeping it in 3rd instead of going to 4th. Smart cookie you are.
eh, use slicks, you'll hook off the start.
Old 06-17-2010, 04:55 PM
  #153
VeNoM0713's Avatar
haha thanks.. and yeah, i have slicks so im good there also. if i dont hit 11's this year im going to have to kill myself lol.
Old 06-17-2010, 05:10 PM
  #154
ItalianJoe1's Avatar
Originally Posted by Witt
Aftermarket sleeves if you can afford/aquire them, I have no idea who manufactures anything off the shelf anymore, been a while since I owned a Cobalt. When you have the sleeves installed, I'm sure this will be a given but just in case, make sure they are honed with a torque plate, call around and see if any local machine shops have an ecotec torque plate, not many do. Whoever's pistons you end up installing, make sure you use their recommended clearances to a tee. Also shoot for the ring manufacturer's recommended rings and gaps. I've used OEM bearings on the rods and mains to GM's specs with no issues, be sure to check those especially if you end up line honing the mains.
When you sleeve it, I'd suggest sending it to Darton/Bates directly. I know any shop in theory can install sleeves, but it seems that the pricing is about the same, so might as well have the guys who designed them install. I sent an LNF block to Darton East and had it sleeved, bill was around $1500 including the return shipping, that's the sleeves and installation, honing to match the pistons, decking the block, all that good stuff. Block came back looking beautiful, clean as well.
From the way you said it blew, you for sure popped a sleeve. Probably the side of #1 or #4, mine was the right rear corner of #1 sleeve
Old 06-17-2010, 05:19 PM
  #155
Stiner's Avatar
fair enough either way there's still power up there with a decent sized turbo. I don't want to completely hook up I like my tranny lol
Old 06-17-2010, 06:34 PM
  #156
VeNoM0713's Avatar
oh crap.. i forgot, should i stick with the ngkbkr7e's? or should i go another range colder? if the turbo is good for it, im going to run 25 psi and ill probably be in the range of 400-420 whp.. i just dont know if i should stick with those plugs.
Old 06-17-2010, 08:00 PM
  #157
rockSTAR_SS's Avatar
Well after all of this talk about Bates Engineering I finally decided to get in touch with him and talk to him about a block with forged sleeves. I sent him an e-mail. I'm kinda unable to give him a call at the moment due to my working hours, but hopefully we can do business through e-mail.
Does anybody know if he responds to emails often?
Old 06-17-2010, 08:16 PM
  #158
VeNoM0713's Avatar
i would say, call him.. i emailed him first and then called him and left a voicemail.. needless to say, hes pretty hard to get ahold of lol. but i finally did, through the phone. he never replied to my email so i would say keep callin him lol. my block will be done next friday : ) im so excited
Old 06-19-2010, 09:42 PM
  #159
VeNoM0713's Avatar
*Bump* for spark plug info!
Old 06-19-2010, 09:48 PM
  #160
Stiner's Avatar
I think he just wanted to know if he should go colder or continue running bkr7e's since he'll be runnin 25 psi
I dont have experience with that much boost but I know other just dropped the gap down a bit and continued runnin bkr7es
Old 06-19-2010, 10:48 PM
  #161
VeNoM0713's Avatar
exactly, thanks for clarifying my last post lol.. i hope someone can chime in on this.
Old 06-19-2010, 11:44 PM
  #162
hungryhip-ccp's Avatar
I ran 8's for awhile when i was pushing 22-23psi on the S256 i was reading the ground strap of the plug to make my determination.
It takes a few sets of plugs to read them properly. The way i do it is throw in a new set of 7's and run a few high boost runs then pull th plugs and look at the ground strap you want the purple/bluish mark just rounding the turn on the ground strap and not really going all the way to the threads. if it goes all the way to the base of the threads then you need 8's
also keep you gap tight, real tight i was gapped @ 26 i tried 30 then 28 and it will still blow out spark when it was really cold outside. i gapped em to 26 and never had a problem again.
also take a piece of sand paper and run it against the bottom of the ground strap a cpl times to remove any burs or pieces hanging down from production. they can creat hot spots and act like glow plugs. this will also ensure your gap is true.
hope this helps some.
Old 06-20-2010, 12:14 AM
  #163
VeNoM0713's Avatar
thanks chris.. lol this crap is too complicated for me. how do you know when you get spark blowout?
Old 06-20-2010, 12:33 AM
  #164
when it pops/backfires at the top of the revs at WOT kinda like cuts out if its really bad. but usually just kinda misses a beat.
http://www.youtube.com/watch?v=fiMM2S0aADM
i actually found this just searching for a sec, touches on the subject but shows a plug at almost optimal heat range. perfect is when the color just rounds the bend.
Last edited by hungryhip-ccp; 06-20-2010 at 12:33 AM. Reason: Automerged Doublepost
Old 07-01-2010, 09:21 PM
  #165
VeNoM0713's Avatar
I'm bumping this! I now have my new clutch (ACT 6 puck) LNF TOB, all fluids pretty much.. my new block will be here tuesday! god im getting excited lol.
Old 07-02-2010, 09:34 AM
  #166
rollingboostedss's Avatar
sub'd for pic's and more details
Old 07-02-2010, 11:21 AM
  #167
X2^
good to hear everything is coming long boss man
Old 07-02-2010, 09:39 PM
  #168
In for pics of that Ray Bates block...
Old 07-02-2010, 10:07 PM
  #169
Jrhdpaintball's Avatar
me as well, and if you had any pics of how you sent it out/received it. not 100% sure how he was describing how to secure the lid on the container. lol
Old 07-02-2010, 10:24 PM
  #170
VeNoM0713's Avatar
i wish i wouldve taken a pic of how i secured it. but pretty much i used this:
http://www.sterilite.com/SelectProdu...=182&section=1 this is the EXACT conatainer i used. i bought mine from walmart. and then i drilled holes all around the top of the lid, used 20 zip ties and zip tied it shut and then duct taped the **** out of the top half : ) for packing, i bought like 4 newspapers.. used all of those and then i bought 2 rolls of the bubble wrap and wrapped everything. i made sure nothing was going to break thats for sure lol. any other questions, feel free to ask!
Old 07-02-2010, 10:37 PM
  #171
lol awsome man, really appreciate it. did you just keep the short block done? and how much did it run you all together?
Old 07-02-2010, 10:58 PM
  #172
VeNoM0713's Avatar
you mean did i send ray my short block? no i didnt. my block is toast lol so i bought one of his. apparently he has brand new blocks so i took one off his hands for $300 but altogether i paid 3 grand including shipping. its alot of money but now im going to have piece of mind and when i go to the track, ill be able to finish in 3rd gear instead of 4th.
Old 07-02-2010, 11:08 PM
  #173
jonxxxedge1's Avatar
i hope your tranny holds up man
Old 07-02-2010, 11:10 PM
  #174
VeNoM0713's Avatar
hey, dont jinx me lol.. its not like im gonna have 1000 whp or somethin lol.
Old 07-02-2010, 11:12 PM
  #175
ive seen a lot of people on here latley having issues with there transmissions. are you still on stock axles?
Quick Reply: Well, I finally blew up... Need advice
