Well, I finally blew up... Need advice
#176
yeah im gonna do what chris did.. set his WOT BOX nls time to .700 of a second so he could shift nice and slow but still be in boost in the next gear. but really, i dont bang gears.. i only mis shift lol.
lol, no... i have the DSS stage 2 axles. i dont know if stock axles can handle 6k launches on slicks.
#177
#183
#184
I made at least a 50 passes on my slicks and I'm still using the stock axles to this day.
I'd rather snap a axle than bust a transmission. Axles are 80 bucks, transmissions tend to be a couple grand easy.
#191
Good to hear, in for pics!
I'm still pissed off. I talked to Ray about a week after I sent my block off to Darton. I almost passed out when he told me that he had a few GM race blocks already sleeved sitting outside.
Oh well...
Oh well...
#192
Brutes..I'm planning an engine build soon not a typical one though...
#195
As far as I stand with the Delta and ECOtec products, you go to Ray Bates if you need anything for the motor and you go to John Powell if you need anything for suspension/driveline...
#196
Eh, I should have worded it differently. It's a LSJ short block prepped for GM racing w/ a better sleeve than Darton. Ray basically picked up a shitload of GM-R parts that GM was looking to get rid of, and it was fresh on his mind that weekend because he had it all outside while he was trying to reorganize inventory to get everything back inside.
There is a RL owner who just got his block from Bates and had it installed by Maven and he is running into a bunch a problems.
http://www.ionforums.com/forums/perf...check-out.html
It starts at post 209 with the oil cooler holes not lining up and continues on post 236. Post 282 there is a chewed up crank sensor.
Although it has not been confirmed, we are starting to think that the block started its life as a 2.2 L61 block which is causing some of the issues.
So if you order from Bates make sure you or an LSJ ecotec or going to run into some problems.
#197
mmmmm................
Glad for you bud. Ninja text so no one gets too out of shape....I'm just wondering why he didn't deck your block. Doesn't make any sense to me to not shave a few thousandths off of it just to make sure it's straight and all. Could be warped for all you know. I find that unacceptable and it has made my decision to just let my machinest install my sleeves for me instead of mailing my block off to someone I don't know other than what I've read on a forum.
#198
I would be careful ordering race blocks from Bates.
Regardless, Venom, good luck man. Looking forward to your progress...
#199
Its not my engine.
Its easy to say "Should have", "Would have", "Could have".
I just wanted to let people know that just because Ray has a bunch of race blocks sitting around, that does not mean they are ready to bolt into your car. Make sure to know what you are ordering before you trust someone with $1500.
