Went on the dyno today
So I went on the dyno today and I wasn't to impressed with my results at all. I have gm stage 2, nates 2.9 pulley, vibrant header/dp, GM performance cat back exhaust and the injen cold air intake. My highest hp was 222. Also after my 3 runs of vibrant header was glowing. I never seen a header glow like that before is this normal? What could be wrong with my car that I would be hitting that low.
yea, your header will get hot and turn red with all that heat passing through it. As with any metal, it will do that... if it got hot enough it would even turn purple.
I will post my dyno sheet in the morning need to get to a scanner. I was red lining at 7K. I am hitting around 16 psi or so. When I was done everyone though I was stock which sucked.
Yah I know, something has to be wrong for me to be hitting that low. The guy operating the dyno asked me if I was stock so I knew my numbers had to be shitty. I was pretty upset with that.
have u had a chance to race against other comparable ss's? If so how did that turn out? Are u able to beat the stock ss/sc? Maybe his dyno is just way out or something.
and u know the rite peddle is the gas peddled eh? JK lol
i would have to agree with u then, u have had the same set up so u know wat it takes. Oh and i love the sig by the was And I dont care for Reign SS lmao
Never raced another SS/SC yet. But when I put the header/dp and the 2.9 pulley I thought I lost power but needed the dyno to prove it. I am going to scan the sheet right now.
sounds like your tune is very messed up if your lean up top witht he 42 pounders. stage 2 with a 2.9 should give you alot better numbers. since your in halifax im guessing your close to sea level like i ma and you should be putting more like 240 to the wheels if not more witht he mods you have
