What is a good air fuel ratio
I seen posts on this board where people are quoting air fuel ratios wrong. When you say air fuel ratio, the ratio is just that x amount of air to y amount of fuel. You will always have more air than fuel. For example 14:1 A/F ratio is 14 parts air to 1 part fuel. It just so happens to be a good ratio for idling and cruising under minimal load. Now let me give you some good examples of air fuel ratios for a force inducted car (turbo/supercharger/N2O)
14.7:1 is the target air fuel ratio while idling and cruising the car under little load.
20:1 is very lean mixture that you will see when deaccelerating like slowing down after a higher RPM.
12:1 is a good WOT (Wide Open Throttle) air fuel ratio.
Some people like to play it safe and run 11.5:1 under WOT. In a sense a richer A/F ratio can act like a chemical way to reduce ignition timing and there for reduce detonation/knock. A richer mixture will burn slower than a lean one. It will also burn cooler and therefore make less HP/TQ.
13.5:1 is a good A/F ratio for a naturally asperated car at WOT.
I have some experience with the A/F ratio's and actually 14:1 is stoic. This meaning perfect anything higher is lean. a 12:1 is good but on a supercharged car you can go a little higher and get more out of it because you do not have the spikes that the turbos have. 12:1 is great for a turbo but i think that you can push 13:1 on a supercharged car because the boost doesn't flux like a turbo so there is less room required for error. just my 2 cents
I prefer to run the car leaner in a low to no load situation to conserve on fuel. Many manufacturers are doing this.
Originally Posted by R33P3R007
My car runs about 12 and spikes at around 4500-5000 upto like 20. it did it on all 3 dyno pulls. Is there anyway to check and see what is wrong there?
Originally Posted by theBLUEone
Thanks alot! This helps alot, I plan on investing in a wideband soon...
I just picked up an AEM WB02 for $200.00 Shipped. It was used on two dyno pulls then the person went AEM EMS and wanted to sell it.
z28addiction
09-28-2015 12:03 AM
OrangeCoba
09-25-2015 06:06 PM
