What is needed besides clutch to change out the clutch
I've tried doing a search, and as you can imangine, doing a search for anything clutch related gives you a couple thousand replies. I'm changing out my clutch this weekend. I'm going with a Spec 3 +.
I'm wondering what parts are not reusable that I'll have to replace that wouldn't come with the clutch. I plan on going into a dealership tomorrow morning to make sure I have everything come the weekend.
Ok, I read some materials on how to do it, and the only thing I don't have is a new throwout bearing. However, it says a new on is not needed. I'm wondering if I should get a new one or not.
So waste of money or good investment
Last edited by NGalaxyTimmyo; 03-18-2007 at 08:47 PM. Reason: Automerged Doublepost
I would get a new slave cylinder, but good luck getting ahold of one. They are on nation wide backorder the last I knew. That should be all you need for parts though. Make sure you resurface the flywheel too.
I only had a new clutch when mine was done, but I did have it done at 4000 miles. The mechanic told me it the throw out bearing was cherry. If you have low miles on it I wouldn't worry about it.
Getaway_Driver
40
09-10-2015 09:11 AM
