What should I gap my plugs to?
^^ bullshit.
gap your plugs for YOUR car.
a rule of thumb is, you want the largest gap you can possibly run, without misfires or sputtering, or any blowout.
ONLY go smaller if you have to.
I recently spent an entire day checking gaps and test driving,
knock was evident at 0.32, and got worse if i went lower. (this is with 94 octane)
0.44 had some sputtering.
anywhere from 0.35 to 0.40 was basically the same performance,
0.38 ended up feeling like the best spot for my car.
dont listen to everyones ideas on what should work, find out what YOUR car likes.
go out and test it on your car. try 0.42 and see how it goes.
if it doesnt feel smooth, or you have any blowout or sputtering, go a bit smaller
3.30" to 3.20" supercharger pulley - .045" gap
3.10" to 3.00" supercharger pulley - .045" gap
3 - 2.90" to 2.80" supercharger pulley - .040" gap
2.70" to 2.60" supercharger pulley - .035" gap
2.50" supercharger pulley - .035" gap
Fail Less.
my '06 owners manual recommends .042 for all our engines. *coughBULLSHITcough* after my stage 2 install i gapped my plugs according to these specs and it ran like ****. lots of hesitation. gapped them to .035 and it runs much smoother. i wish i had a way to monitor KR
Tkolb325 - the stock plugs are NGK PFR6T-10G. they are platinums. found here
Rent me! per hour
stock plugs are not platinum.
iridiums.
huge difference in metallurgy here.
every car is different, you can not tune two cars the same way, you can not gap spark plugs the same
iridiums.
Location: Voted by the people, most likely to get pulled over by a cop
btw, why are people paying $15 for plugs? They are like $1.77 each at Autozone
Fail Less.
NGK --- Double Platinum --- 5542 --- PFR6T-10G ---.040" --- Supercharged --- $11.71
Good advice from many of you.. Thanks for the continued input.
I think I will try again with .38 like you said an0malous. You seem like you know whats up in every other post of yours I have read. But I will keep in mind every car is different, so I will probably spend the day testing and seeing what works best.
Thanks again guys, and keep the input coming. I think this may be an ongoing situation for me..
#36
#40
^^ bullshit.
gappin my plugs at.035 like everyone does with a 2.7 is useless, near the top of the rpms i got some sparkblow out, upped the spark dewll in hpt, which helped alot, but didnt want to up the dwell too much due to premature coil pack failure.
tested it again and every so often blowout would occur but it wasnt everytime like it was previously, regapped to .032, still havnt had a chance to hammer it but im sure it did the trick cuz it was almost all gone the first time around.
this means nothing to me LOL
#41
I was getting hesitation with .039 an autolites. Also a lot of random knock. I moved to NGK IX and gap to .035. knock on initial throttle only, much less hesitation. I'm going to play with it more. Not sure if going down is the answer right now or going inbetween. I'll have to see what happens. the .039 also had a little excess carbon on them oil and gas was coming out the exhaust. No gap setting might fix the total issue there. Will update if I find one though.
#42
what octane are you runnin liol?
Gap can effect knock, but theres also a definate possibliity, that your going to knock due to other factors, regardless of your gap.
If your car feels better at 0.35, stay there.
in my experience going lower than that will increase your tendancy to knock.
#43
I'm going to test out maybe inching it up some, but .035 has so far performed worlds better than .039 under very close observation.
#44
i see "intense suspension package"
what have you got done there?
I know if i tighten down my Ingalls I get a tiny bit of phantom knock.....
so you gotta watch anything that stiffens up your motor, that can definately cause it.
#45
What is the part number for these ZEX plugs?
http://www.compperformancegroupstore...ode=SPARKPLUGS
ALso, who prefers the ZEX plugs over the NGK bkr7e plugs? Also, how often should we be changing the plugs on a SS/SC 06 stage 2?
Thanks
Thanks
#47
The BKR7E is a copper plug thats why he had better performance from the ZEX, the BKR7Eix are the iridium ix plugs that are 1 step colder and if you go by what cobalt-addiction.com lists....you should run them at .40 gap........
agentirons
10-16-2015 02:11 AM
