What's Ur Coolant Temprature
Old 04-16-2010, 02:39 PM
heartmycobalt's Avatar
176-178 normally, if its hotter then around 180 but rarely does it go above that.
Old 06-10-2010, 11:27 PM
SunburstSS's Avatar
my temeratures don't go above 185 ' now, & the temp out side is over 90 ' , my cat. convertor was clogged so it didnt allow enough flow, so im good now
Old 06-11-2010, 03:11 AM
Omega1x's Avatar
Mine does right around 180 while cruising. And it has gone up to about 212 at idle, never higher.
Old 06-11-2010, 03:16 AM
Berto09ss's Avatar
192 summer and 188 winter
Old 06-11-2010, 03:08 PM
doubledamageXX's Avatar
stuck in traffic, itll go up to 220 before the pump turns on, and it shoots back down to like 180, daily driving, bout 185-195 summer and 180-185 winter
Old 06-11-2010, 03:13 PM
tony2toness/sc's Avatar
alright guys i got a question regarding this at what temps are the fans suppose to turn on cause my fans dont turn on unless i turn on the ac and i see temps go above 190 to 200 now i never saw that in my car before my car always stayed at 180 to 190 depending on traffic
Old 06-11-2010, 03:21 PM
selfinfliction's Avatar
mine stayed at 180 cruising with the supercharger... with the turbo it's 185 cruising i have modified fan tables on the pcm though too, don't like how the oem settings have the fans kick on so high so i changed all of that stuff
Old 06-11-2010, 03:26 PM
light'bolt's Avatar
waiting in line at the drive-thru it'll go to 210 in the summer heat. On the open road it hovers around 175 +/- 5
Old 06-11-2010, 03:32 PM
blk06cbltss's Avatar
never above 190's, even when its 120 out =D
Old 06-11-2010, 03:46 PM
change your fans to start kicking in at 195
Old 06-11-2010, 06:10 PM
  #36
Frew's Avatar
before the head swap 180-185, after 185-190, both cruising *shrugs*
brandon04
10-21-2015 07:04 AM
vjoel2011
10-02-2015 12:11 PM
grampss
09-27-2015 08:51 PM
riceburner
09-26-2015 12:57 AM
ATOMbomb
09-11-2015 10:48 AM
Quick Reply: What's Ur Coolant Temprature
