Why PCV Valves SUCK. And pics of my S/C...
Old 03-22-2008, 05:32 PM
SloBaLt RiDeR's Avatar
Anyone got any videos of sound difference? of sealing the 2 intake holes wit quiksteel
Old 03-22-2008, 06:42 PM
Fail Less.
Bika's Avatar
F the fuel trims. i know its not lean (wideband readings). im about 2 seconds away from going in with my HPTuners and disabling that code if there isnt some legitimate purpose for having the valve cover vent back into the intake.
Old 03-22-2008, 06:56 PM
RaineMan's Avatar
install a catch can... or just put a breather filter on it man...
Old 03-22-2008, 07:00 PM
FryLoch's Avatar
What's the advantage to blocking those holes?
Old 03-22-2008, 07:02 PM
ecotecon18s's Avatar
its supposed to make the s/c louder
Old 03-22-2008, 07:06 PM
Fail Less.
Bika's Avatar
breather filter mod is we already did and got the CEL. i dont think a catch can is going to do much and they are like 50 to 75 bucks
Old 03-22-2008, 07:30 PM
Rattlesnake Race Shop
USMCFieldMP's Avatar
To tell the truth... I don't really think that it is any louder at all. But maybe it's just me... I'm not good with that sort of thing.
Old 03-22-2008, 08:17 PM
Blackout06LS's Avatar
The REAL advantage is no dirty parts. That's all I care about.
Old 03-22-2008, 08:27 PM
hungryhip-ccp's Avatar
Originally Posted by SilverSS/SC
I just got rid of that hose and put a small breather filter on the valve cover nipple .
most other get a p0171 fuel system to lean bank 1
Old 03-22-2008, 08:36 PM
SSdan's Avatar
It is, everyone I knew noticed mine..
Old 03-22-2008, 09:24 PM
  #36
Well... since I made the post last night... lol.
I've only got maybe 4 miles on it so far. BUT, I'm about to go do some boosting... so we'll see.
QuickSteel is very strong, and I shouldn't have any problems. As I've said before... a lot of GTP owners that I know have been running it with 2.55" pulleys for 50,000+ miles... looks the same as the day they put it in.
You are going to throw a p0171 garanteed...
going to do this mod when i return home! i will post video of before and after
Last edited by hungryhip-ccp; 03-22-2008 at 09:24 PM. Reason: Automerged Doublepost
Old 03-23-2008, 01:41 AM
  #37
Haven't thrown a code yet... and I drove a good 300 miles today.
Old 03-23-2008, 01:59 AM
  #38
rukkee's Avatar
Best solution imo .
Old 03-23-2008, 02:38 AM
  #39
And that is probably what I'll end up doing.
Old 03-23-2008, 06:57 AM
  #40
SilverSS/SC's Avatar
Ive seen the cars that do have them , they do trap all the oil in the can . So if u do intend to keep the pcv tube , and your intent is to keep oil out , it isnt a wasted investment .
Old 03-23-2008, 07:06 AM
  #41
Turbo06Sedan's Avatar
For you guys that are getting the P0171, try unhooking your battery for 15ish min.
I know that when I drove from CA, to UT the altitude difference, and the fuel (used 87 at the time to get there), was making my car feel slowww.
Filled up with 91, unhooked the battery. Smoked a cigarette or two. Rehooked it back up, let her idle for 5-10 more minutes. she ran perfectly fine.
Old 03-23-2008, 02:21 PM
  #42
Fail Less.
Bika's Avatar
id rather lose the breather tube if it wont hurt anything other than a stupid p0171 code. hot valvetrain air in intake is FTL.
Old 03-23-2008, 03:21 PM
  #43
huh im still pretty convinced you will... what happens is the air that was recirculating into the intake tract was unburned fuel and it helped enrichen the mixture. now elevation and things will change peoples results... its not the thing beeing unhooked that throws the code it your fuel trim will adjust for the difference and weather or not you go over 17+ long term fuel trim or not will depend on altitude, tune, weather, mods... so maybe you will and maybe you wont but one day you will probaly throw the code and possibly even send your balt into limp mode... so if i were you i would check the how to section and look for installin a catch can for under $20
that "hot air" wouldent even see a 1hp loss on a dyno... imo go for the catch can its your "best bet"
Last edited by hungryhip-ccp; 03-23-2008 at 03:21 PM. Reason: Automerged Doublepost
Old 03-23-2008, 04:13 PM
  #44
Well... since the hose is still connected... I don't think I'll be throwing any codes... lol.
Old 03-23-2008, 04:20 PM
  #45
no you should be perfectly fine then...
Old 03-28-2008, 12:40 PM
  #46
1BadBlueSS's Avatar
how would you go about cleaning a dirty Throttle body???
Old 03-29-2008, 01:45 AM
  #47
I used a pair of boxers and wiped it off.
You can move the butterfly around and ****... you aren't going to break it.
Or you can just buy a can of throttle body cleaner. I'd say to take it off... and wipe it off.
Old 03-29-2008, 04:53 PM
  #48
montecarloman's Avatar
Gum cutter or carb cleaner, a tooth brush, and a rag. Spray it down, scrub it, spray it down again and wipe it clean.
Old 11-05-2008, 11:56 AM
  #49
Preowner's Avatar
Sorry to raise a dead thread but I too am getting a CEL. I'm using a breather filter and capped the intake barb. It usually goes away after a few days but will come back the next day. I recently got a scangauge and cleared the CEL a few times but it keeps coming back.
I'll need to find the tube again and put on a catch can. I made one with <$10 in parts from harbor freight (compressor in line oil seperator and barbs)
I hear this code shows up in other cars at idle if the dip stick is not all the way in. Similar situation since the crank case is venting.
BTW has the silencer plugging held up? I'm interested in trying something like that, but I hear it always seems to "disappear" into the intake. It looks like the holes are too big to just epoxy closed.
Old 11-05-2008, 04:11 PM
  #50
My plugs are still there more than 10k miles later.
Quick Reply: Why PCV Valves SUCK. And pics of my S/C...
